Question about AOC CT720G 17" CRT Monitor
No display on AOC 17" CRT Monitor
I was having the same problem w/ my monitor..I thought it might be the video card problem, but when i changed the port to the buitl-in video socket, there was still no display on my monitor..only green light shows and after booting..it will set the monitor on steady mode werein green light blinks only but no display.
My AOC 17" flat monitor (model number P7S80) is not displaying properly. Only 80% of monitor is displaying and the edges at the bottom are tapered of. If somebody is having a solution please post it.
Posted on Mar 11, 2010
AOC CT720G (Black, Silver) 17" CRT Monitor driver
The monitor probably doesn't require any special driver. There are drivers for your motherboard video chip, or if you have a graphics card. If you need to make adjustments to the monitor, the manual is here... http://www.manualslib.com/manual/8152/Aoc-Ct700g.html
Jul 10, 2014 | AOC CT720G (Black, Silver) 17" CRT Monitor
Aoc 17 flat crt p7s91
Change the video-card inside your computer, and install the correct drivers for the new video-card.
Dec 24, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
Screen got yellowish color
Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing.
Open the monitor and ring coaxial wire in blue insulation.
Sep 11, 2009 | AOC CT720G 17" CRT Monitor
CRT EV730 Monitor Just went out won't power won't do any thing
Check the color of the pluggie that goes into the back of your monitor, it is most likely either blue or white. Find a friend who has the same color plug and borrow their monitor for a few minutes. If theirs works; your monitor has **** out. If theirs does not work then your video card (on-board or add-on card) has **** out and you'll have to have a new card added to your system.
Jun 22, 2009 | AOC CT720G 17" CRT Monitor
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
Hi...my AOC 17" CRT monitor display on the screen says NOT SUPPORTED OUT OF RANGE... i try to change the screen resolution by using other monitor but still nothings happen..
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Dec 12, 2008 | AOC CT720G 17" CRT Monitor
AOC 17" Flat CRT Monitor
Could be problem of key switches!
Try replacing or check for leakage,high resistance across switches using ohmmeter.
Samir
Jul 26, 2008 | AOC CT720G 17" CRT Monitor
Problem in my aoc monitor
pls replace control button 4no
Jul 12, 2008 | AOC CT720G 17" CRT Monitor
Im having monitor problems
have you tried replacing the video card?
Oct 01, 2007 | AOC CT720G 17" CRT Monitor
AOC CT720G 17" CRT Monitor Logo
812 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
