Question about Linksys Wireless-G WRT54G Router
How to connect my laptop to the wireless wrt54ga linksys router
  • 30 Answers
Just go to www.linksys.com/kb select the model no.of your router and you will get step by step help to setup your router. you can also call linksys tech. support and i am here to solve your problem.
if this is a new router then connect it to your system through ethernet cable and go to internet explorer and type 192.168.1.1 at the add. bar it will prompt for the password. leave the user blank and type admin in the password linksys setup page should open. now click on the WIRELESS TAB and on the basic wireless settings change the defale SSID NAME to your girlfriend's name and also click on reset security and click on save settings. reload the page and now go to wireless security tab and select WEP in the security tab. now type 10character password in the KEY 1 field directly and click on SAVE SETTINGS and that's it. Now when you connect to your network you will have to enter your 10 char password in your DELL LAPTOP and it should work fine now.
Posted on Sep 07, 2009
    President:
  • 392 Answers
Connect it with a Cat 5 E ethernet cable. Insert one end to the linksys router and another to the laptop. Then if u want to configure your router, insert the router software CD and follow the procedure mentioned in the CD.
How to configure roaming in linksys WAP54GPE
Do you mean how to connect to your Linksys wireless router in your home using a wireless connection?
If so then -To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 27, 2012 | Linksys Computers & Internet
I cannot make a wireless connection my new laptop to the linksys router. My homenetwork works and my first laptop is connected to a wireless linksys connection. when adding another laptop I cannot make a...
then it's the second computer's problem, try repairing the connection, turning the wireless switch on and off, rebooting, and if your using vista use windows system file checker
or if xp, put this in either command prompt or run
chkdsk /r
Sep 30, 2009 | Linksys Wireless-G WRT54GS Router...
Laptops connect to router but still cannot get on internet
It's just a wireless interference problem. All you need to do is change the wireless channel of your router. Login to the router's admin page and look for wireless channel under the WIRELESS tab. Change it to channel 11 and save the settings. That should solve your problem. You can play around with different channels and check which one is the best for your environment. Good Luck!
May 07, 2009 | Linksys Wireless-G WRT54G Router
Slow wireless internet connection for select PC's; fast for other
Make sure that your wireless mode is set to "mixed mode".
Intermittent Connectivity:
NOTE:
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 20, 2009 | Linksys Wireless-N WRT150N Router
Cannot connect to wireless network
To connect to the linksy's router you will need to run the linksy's setup disc on each pc in that netwrok.
Mar 29, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Connecting wireless router to my laptop
you have to open up the wireless menu on the laptop and have connect to the linksys, which will be your router and it will ask for a code and that code is on the back of the router and you will connect as soon as you put that code on there
Jan 31, 2009 | Linksys Wireless-G Broadband Router
Cannot connect laptop to wireless router
probably nothing..go to the maker of your computer, and get a fresh wireless driver set..maybe the old one did not include linksys..it does happen in MSoft land.
Oct 16, 2008 | Linksys WRT160N Wireless Router
Laptop setup
just connect the linksys router to wireless router and just install the setup cd given with wireless router ..after configuring your laptop just insert the cd in another laptop and copy WEP key in it and get connected through wireless network
Jun 19, 2008 | Linksys Wireless-G Broadband Router
My laptop won't work wireless
Use windows network setup wizard to help in setting up your wireless. The wizard can search for your wireless. Some people believe you gan get away without using Linksys's software & I agree to a point. However Linksys believes to maintain a good connection you should install the software for the wireless router. You can download it from the link below. Check out the link "Learning Center". You might find it helpful. http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
I suggest to all running a wireless connection to set up security with a password to keep freeloaders from tapping into your bandwith for free.
Luck!
Please vote...
Jan 23, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
65 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
