Question about Canon PIXMA MP830 All-In-One InkJet Printer
Leaking ink pool of ink collects where paper exits machine; changed all cartridges and still the leak persists... I cant get into the machine to see if there is a larger pool on the inside. It originates from the middle of the rollers. Any suggestions would be helpful; also clean-up tips for ink ;)
  • whsantos Dec 16, 2007
    Having the same problem. Tried the same solution (changing out tanks)... no help.
  • 70 Answers
There could be two problems.
1. Left over ink. Requires a complete printer cleaning from the inside. You will have to open it up and clean it.
2. If you have replaced the cartridges and still the problem persists, it means that the print head needs to be changed. It is malfunctioning and thus allowing more flow of ink from the nozzles.
Posted on Dec 20, 2007
Ink leaks and pools in right back paper tray and leaks onto desk
it sounds like your collection assembly is full. this is not something you can do anything about. it must be replaced and it will be costly. you are probly better off to replace it
May 18, 2017 | HEWLETT-PACKARD Office Equipment &...
Why do my incoming fax sheets have black ink all over them can not read fax
well i think that the paper u use in ur fax machine creates a colour bleed over it. so i reccomend u that use low porous papers. but do not use blotting papers or porous papers as while printing the fax page, porous papers soak high ink and it gets scatterd over.
another sollution- please check the cartridges because if the cartridges leak, then it may lead to spread blank ink over paper......
check these simple steps and then if the issue persists inform it again....
Jan 14, 2011 | Office Equipment & Supplies
I have ink leaking and spraying inside the machine!!
Open the cover. Take a lot of tissues. Find where your cartridges are usually located, when they are not printing. There should be a sponge there, which is probably full of ink (that's normal). All you need to do is wipe your printer, especially the sponges. If the cartridges are also leaking, take them out of your printer, put them on some tissue, so the excess ink can drain on the paper. Check the cartridges after several minutes, if they are still leaking, leave them again on some paper or tissue, until they stop leaking.
Hope that helps!
Mar 04, 2010 | HP Photosmart C4280 All-in-One InkJet...
My epson stylus photo printer is printing a black vertical line in all my prints. I have done the head cleaning and print head alignment several times. Is there anything else I can do?
black vertical lines on the printout comes due to some reasons.
1) if the black cartridge is near to its end it will give black lines instead of proper printing.
the cartridges gets over many times due to head cleaning and deep 3-4 cleanings cartridge gets one cleaning 4 ml of ink gets puled out of cartridge.the whole quantity of cartridge is near to 25 ml.
but if the cartridge is full then the problem is of cartridge head .the head is the part in which you insert the cartridges if the head is got blocked internally to its holes from where ink comes out.then there are two methods to clean the head one is head cleaning which you did.the other is removing the head by disassembling the printer and then cleaning the head manually with isoprophyll liquid.but its a time consuming and tough job.a local printer repair center will be advisable,
and in some cases it has seen that cartridge gets air pressure problem inside and due to that it leaks inside the printer so replacing that cartridge solves the problem.also many times the cartridge gets leaked and that leaked ink gets collected and stuck up on the roller of the printer from where paper passes so the strips of ink gets printed on the this case no head cleaning but cleaning the internal roller of the printer with tissue paper helps.the procedure is called servicing.that can also be done at local printer repair center.or you can do it manually by using tissue paper.but to service whole printer it needs to be disassemble.
check out his option.thanks.
Nov 20, 2009 | Epson Stylus Photo 1290 InkJet Printer
Black ink spot on printed page
Does this ink spot persist if you change the black cartridge for a new one? If not, it's just a faulty cartridge seal. If it persists, you must have a leak from the print-head somewhere - this would probably require you to dismantle the printer to locate it. For example, the waste ink pipe may be blocked and the head is just swimming in black ink (the one you use the most).
Please report back if you need further help on this.
May 20, 2009 | Epson Stylus C84 InkJet Printer
Leaking black in from the bottom of the printer
actually your printer needs servicing but for temprory solution.take a bunch of tissue paper .keep the printer on and the printer cover open so the cartridge will be in the center.then with the tissue paper place it internally on the side from where its leaking.the sponge which collects the wastage ink is at present got full and now it does not have the capacity to soak the its you will place the tissue papers the ink will be soaked by tissue paper and the sponge will again become bit dry to soak more ink.but its the temprory make it permanent get the printer serviced and sponge replaced.the problem is not all serious ,its common.every printer comes to this stage after certain usage.and the servicing is the solution.a local printer repair shop also does the servicing job .
hope this helps.
May 03, 2009 | HP Photosmart 8250 InkJet Printer
HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
Mar 06, 2009 | HP DeskJet 930c InkJet Printer
Toner leaking ink on one side of paper pretty bad
There could just be a lot of toner inside the printer, but it could also be the drum unit (which also collects the waste toner) is so full that it is leaking.
This typically happens when the 'replace drum' indication is reset without actually replacing the drum.
If you have reset this without replacing the drum, and the print count is in excess of 30,000, you probably just need to replace the drm unit.
Mar 05, 2009 | Dell Laser 1720 Printer
Ink keeps leaking from the printer!
The problems you are experiencing are due to ink buildup in the ink absorbers that reside in the base of the printer. I'm surprised that you did not get a "ink absorber almost full" message. Unfortunately this occurs when more ink (heavy printing) goes in to this area than the ink absorbers can absorb and the ink starts to build up. An ink waste tube feeds in to the absorbers right in the front middle of the printer. When the ink begins to build up, it comes up through the paper platen there in the front causing the ink problems on the back of your paper.
The machine will need to be serviced. Canon suggest replacing all of the ink absorbers which is the easiest thing to do from a Tech perspective. The last machine I had in with this problem, I tore down machine and just rinsed all of the absorbers. You also have to rinse the underside of the paper platen.
Oct 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Newly Installed 7680
probably you did nothing wring, I seen a few of these cartridges leak - HP should replace the machine if the damage was caused by original cartridges.
Apr 21, 2008 | HP Officejet Pro L7680 All-In-One Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
308 people viewed this question
old marine
old marine
