What does v chip mean? My TV is working and on the screen it says "V chip has been activated".
  • 855 Answers
V chip is a generic word for the chip in your tv that controls what you can watch by the ratings. This is used by parents to restrict what programs thier children can watch. You can access this settings in the menu of your tv.
Posted on Sep 07, 2009
My television shows a small line not a full screen
If its a horizontal line in the middle of the screen do not switch on the TV till you fix it. It means you have lost the vertical amplifier IC ( chip ). If you continue to turn on the TV the phosphor in area where the line is coming will get permanently burnt and do not look at the screen it can cause retina ( eye ) damage.
Take professional help to replace the chip.
Jun 02, 2011 | Hisense TC24FS2H TV
How do I remove a Vchip from a Sharp TV no code?
Default code is "0000" on most sharps to enter the V-chip settings. If not you will have to reset the password which is listed in the manual if you have it.
Clearing the password or secert number on newer sharps are as follows.
1. Press MENU to display the MENU screen, and then arrow to "SETUP"
2 . Then select on of the options until the password or secert number input screen dislpays.
3. Press and hold both the "Channel Up" and the "Volume Up" buttons simultaneously until message apperas on the screen. Then you can enter new or leave blank number.
If this doesn't work goto sharps web site and download the manual if available.
Mar 15, 2010 | Sharp 32C-240 32" TV
V-chip activated
Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN (9) on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be.
Mar 14, 2010 | Sharp 32C-240 32" TV
How to Turn off V-chip
I would suggest searching your Menus on the tv for the option to turn it off. Or search your manual.
most cases will have a parental lock on the chip which is set by the owner.
"Each television set’s V-Chip works a little differently. Once you understand the
definition of each rating and content label, programming and activating the V-Chip is
as simple as following the set-up procedure which can be found in one of two places:
1) the television on-screen menu options, or 2) the written instruction guide included in
the owner’s manual. The V-Chip will only be activated if you select the option to do so."
Pulled from this website:
http://controlyourtv.org/images/content/navigating.pdf
I hope this helps
Feb 17, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I need to remove the v chip from my TV, how do I do that?
V-chip is a set of features not a physical chip that can be removed. It is activated by firmware and shows up as menus in the receiver's setup screens.
Dont set it, and it will not activate... or see your manufacturers user manual on steps to re-set.
Jan 06, 2009 | Televison & Video
Rca lcdx3022
This happens when the tv cpu detects an internal problem, for example an overvoltage, a short, or a faulty component.
The tv goes in protected mode, and activates a safety switch that turn immediately the tv off, that is what is happening to your tv.
Try unplugging the tv for one hour or so, this will drain power from the unit, and reset the TV chips, in case the TV is "wrong" about the problem.
If it does not works it means that the tv has an internal fault, in this case you may need to call a technician if you want to fix it.
If you need to call a repairman you can use the phone number listed on the owner manual.
Sep 14, 2008 | Televison & Video
Parental Control V chip has been activated.
on my Sharp 36R-s400. Go to menu , then parental control. When dispaly asks for secret number,
press and hold volume up and channel down simultaneously until message is cleared.
This turns off parental control and clears the password.
Sep 06, 2008 | Sharp 19R-M100 19" TV
Input password
Problems with V-Chip/Parental Controls
The rating limits don’t work
• For rating limits to take effect, you must lock V-Chip settings to activate them.
I don’t remember my password and I want to unlock the TV
• If you forget your password you can reset it. Enter 5898 as the password and then change it
to a new one.
Dec 12, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
59 people viewed this question
k24674
jasbo
jasbo
