Question about Texas Instruments Office Equipment & Supplies
Anytime i enter an equation to graph it says ERR: INVALID DIM please help
    Brigadier General:
  • 5,158 Answers
You need to turn off stat plot, press 2nd and then the Y= button to get to "Stat Plot" one of them is turned on so press enter and select OFF.
robert
Posted on Sep 07, 2009
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
then select 4:PlotsOff.
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
ERR: INVALID DIM appears every time i try to graph an equation
Deactivate the Statistical plots.
  1. Press [2nd][Y=] to open (Stat PLOTS)
  2. Press [4:PlotsOff] then
  3. [ENTER]
Jun 14, 2011 | Texas Instruments TI-84 Plus Calculator
My TI-84 calculator keeps saying "ERR:INVALID DIM" whenever I try to graph a function. I have used many different equations and tried to reset the scales and stuff in the "WINDOW" but it keeps saying the...
One of the statistical plots is turned ON and you must turn OFF all the STAT PLOTS.
To do so
  1. Press [2nd][Y=] to access the stat plot configuration.
  2. Select [4:PlotsOff]
  3. Command PlotsOff echoes on main calculator screen
  4. Press [ENTER] to execute it.
  5. Return to your [Y=] screen to define functions to graph.
  6. When finished entering functions press the [GRAPH] button.
Aug 31, 2010 | Texas Instruments TI-84 Plus Calculator
Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
May 12, 2010 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
ERR: INVALID DIM (That's the error message I receive every time I try to graph an equation)
[2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Screen shows RAM cleared. Clear the screen and use [Y=] to enter the functions you want to graph.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-84 Plus Calculator
Graph and trace buttons don't work
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
Sep 16, 2008 | Texas Instruments TI-84 Plus Silver...
If either error occurs when trying to graph a function (not a STAT PLOT), the error can be corrected by turning off the STAT PLOTS. The following steps will turn the STAT PLOTS off, allowing the graph of the function to be displayed.• Press [2nd] [Y=] to access the STAT PLOTS menu.
• Select 4: PlotsOff.
• Press [ENTER].
• Try graphing a function like y = x^4-3x^3+6x-1
Jun 03, 2017 | Texas Instruments TI-84 Plus Calculator
13 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
