Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Reset button on washer???
Did two loads and everything was fine. The third load filled and did nothing. There was a smell of burning for a while, but that went away. Is there a reset button to get this machine going before a repairman is needed??? Any assistance will be greatly appreciated
  • LUCY DIAZ Dec 16, 2007
    spin cycle makes noise and doesn't spin
Our washer smelled like burning and reset button totally fixed it, it was under screwed down panel in back
Posted on Nov 03, 2009
    New Friend:
Washer does not turn on,tripped the Main Fuse.
Posted on Apr 26, 2014
  • 51 Answers
If the smell was like burning plastic then it sounds like a motor. No reset.
Posted on Dec 09, 2007
  • Randy Bell
    Randy Bell Jan 26, 2008
    Did you find out the cause?
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Apr 20, 2011 | Maytag Washing Machines
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Jul 20, 2009 | KitchenAid KAWS850L Top Load Washer
Winding sound, with a smell of burning
I recommend to stop the use of the dryer immediately and call an expert repairman to your home. The smell of burning can only mean bad things, so better safe than sorry.
Dec 29, 2008 | Indesit WA 125 Front Load Washer
Model# LW6163WM/LM washing machine
Dear usaguitarman Welcome to
I'm Huuum and happy to assist you,
You said, washer fills with water. then the motor overload protector starts clicking
in and out.and there is a burning smell. I am able to spin the water back out.
The belt needs to be replaced but I don't know if that could cause my problem.
Yes I believe the belt could be the problem!
That is more than likely the burning smell!
Change to belt.!
While your at it, unplug the machine for 5 minutes or more and then it will reset the system too!
Let me know how wonderful it performs after these repairs!!!!!!!!!!!!!
i believe you will be fine!
Bless You,
Please do not forget to enter a rating when you are done.
Thank you
Sep 23, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washer stopped working
If after waiting for a while it still does not respond - most likely the motor is burnt - especially if those were all very heavy loads
Sep 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
My dryer in my stackable washer/dryer quit
I Think the belt got binded on the motor spindle and the burning smell was the belt burned through by the spinning spindle
Mar 23, 2008 | Dryers
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
2,899 people viewed this question
Dan Webster
Dan Webster
Sal De
