I have diy installed a pc desktop, The combination is included new Asrock G31MS motherboard, new Celeron E3200, new 450W power supply w/case, old 250GB SATA harddisk x 1, old DDR2 512MB Ram x 1 and old dvd writer But it is not work, the symptoms are as below. - CPU fan = work, DVD writer = has power - display = no any image, PS2 keyboard & usb mouser = no reaction, - no beep sound and can't load to POST. - it sounded 3 beeps when there hasn't RAMs. It's an appreiated if any experts can help. where is the problem.
  • 6 more comments
  • tlkohk Sep 07, 2009
    thanks for your response.
    i have try to put the ram and start the system but it has no any reaction except cpu fan, dvd writer power and power led. please advice.
    I use the on-board video. the ram, harddisk & dvd writer were working on the ex-PC desktop.
    it can't boot up even no any beep sound. i suppose that it would boot to POST at least if the motherboard is normal.
    please advice.
    if the problem is found in motherboard, i would request supplier to replace it as brought it yesterday.
    yes, i have
  • Agung Mahatma May 11, 2010
    Have you install the celeron processor properly ?
  • Michelle Crabbe May 11, 2010
    You will need to start from scratch. I assume that you or someone you know built the system. Therefore it is best to unplug a great deal of what you have set up already. Start with these steps to find out where the issue is. 1) Unplug the DVD Writer 2) Remove the USB Mouse 3) Remove any external extras you have For example: Web cam, printer etc When you boot with the basics you will have a better idea of what the problem might be. I will also assume that you are using the video that is built into the motherboard? or are you using a card inserted into the slot for video? Also the DDR2 may be incompatible.I would double check the manual for your motherboard to ensure that all your components are compatible with the board. Try and get video first so that you will have the ability to review the cmos. Let me know if this helps you any.
  • Keith Paredes
    Keith Paredes May 11, 2010
    The beeps are normal if there are no RAM, you need the memory sticks to start the system.
  • JDTec
    JDTec May 11, 2010
    3 Beeps: Base 64K RAM failure Explanation: There is a failure of some sort within the first 64 KB of system memory. Diagnosis: The first bank of memory probably has a bad memory chip in it somewhere. It is possible that there is a failure related to the motherboard or a system device as well. Recommendation: Treat as an apparent memory failure. Troubleshoot the motherboard.
    Problem Solver:
  • 17 Answers
CHECK OR REPLACE SMPS
Posted on Sep 07, 2009
I can't open windows pc emahine t1840
If your computer does not respond when pushing the power button you may need to have your computer checked out by a computer repair shop.
Possible causes for this issues include but are not limited to.
1. broken or bad power switch
2. Bad power supply
3. Dead or dying motherboard
All these issues can be replaced / fixed. However microsoft no longer supports windows XP and soon most software may fail to work as well. It may be a good time to look at a new computer, most places offer the option of transferring over old data such as images and documents as well.
Oct 05, 2014 | E-Machines -T1840-CELERON-1.8GHz,40GB...
No VGA output
Hello the drivers site is here:
http://www.asrock.com/mb/overview.asp?cat=Download&Model=G41M-VS3
The manual:
http://www.asrock.com/mb/overview.asp?cat=Manual&Model=G41M-VS3
I think you should drop the onboard graphic and install a better graphic card in the 1 x PCI Express x16 slot on the mainboard.
Check the power supply for any fault.Is it new ???
You can not use the old Power supply because it might have a 20 pin connector this asrock has a 24 pin connector.
Check also you not have used the extenal graphic power connector in the 4 pin 12 + volt on the mainboard.
Check also all your power connections.
Reply me again if you can`t find the fault.
Good luck
Nov 28, 2012 | Asrock G41MVS3 Motherboard
I have an Asrock 775vm800 motherboard, and I would like to know what other motherboards have the similar specifications to be used as replacement for my Asrock. What I mean is, what motherboards I can
Desktop computer cases have a combination of mountings that are standard and will be suitable for motherboards from diffetent manufacturers.
I suggest you select a motherboard that suit your current and future requirements. The only thing you need to be aware is the power requirements for the motherboard and the devices you install with this motherboard, eg. 450 watts or higher.
Aug 11, 2012 | Asrock 775VM800 Motherboard
Need apower supply and hard drive for my compaq presario 1103WM. how old is this unit
It must be up to 8 years old ish as it has XP installed.
17-inch flat screen CRT monitor NEW* Intel Celeron D Processor 3252.53 GHz, 533 MHz FSB, 256 KB L2 cache 256 MB DDR SDRAM CD-RW (48x32x48) 40 GB hard drive 9-in-1 memory card reader 10/100Base-T networking interfaceIntegrated graphics with 64 MB shared video memory *The new Celeron D processors are more efficient than the old Celeron processors. The New 325 D benchmarks faster than the old Celeron 2.7 GHz processor.
Almost any IDE hard drive will work, up to 540Gb and any reasonable power supply should be OK. Check ebay and also google for a power supply.
Hope that helps.
Feb 16, 2011 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
How is the power supply removeddell gx260
Unplug computer and then press power button for 5 seconds to drain capacitors. You'll need to remove the case screws and case to get to power supply. From the back, you'll see smaller screws near the fan output vent of the power supply. All screws are phillips #2. Dell sometimes uses special clips that you have to press or pull to release objects, but may not for power supply. You'll have to disconnect all power cables from all internal devices including hard drives, CD/DVD drives, floppy drives, motherboard and any power assisted graphics cards. There may be additional chassis screws holding power supply to chassis. If you are replacing power supply, be sure new one is of at least same wattage as the original. New supply should match the same configuration as the old one and have the same style motherboard connector. Name brands like Compaq and Dell have used supplys that are specific to their PC lines. But, you should still be able to find OEM replacements. Looking for a replacement, try www.pricewatch.com.
Oct 05, 2009 | Dell OptiPlex GX260 PC Desktop
How can i install my asrock 845 celeron processor sound and video controller driver ?
Download drivers for ASRock 845GV-M from;
http://www.asrock.com/support/download.asp?Keyword=&Socket=478&Model=845GV-M&OS=XP
Regards;
Hassan
Jul 30, 2009 | Asrock 845GV (P4I45GV) Motherboard
No pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
May 02, 2009 | Asrock K7S41GX Motherboard
Upgrade to a new motherboard?
I think there may be another issue.. It could be the power supply.. Have you tried a new one?
Have you installed any additional ram lately?
You can use the old XP software with a new motherboard, but it can be a pain in the **** to set-up if it is the OEM version of Windows, or a Recovery Disk that came with your machine..
What you could do, if you bought another motherboard, find someone with a Genuine Windows XP disk, and use your Product Key to install it..
Apr 12, 2008 | E-Machines eMachines Refurbished EMA...
I have an ASRock AM2NF6G-VSTA motherboard that will not power up. I upgraded the system and powered it up and it ran fine, except I had not received the new upgrade power supply. I received and installed...
check the power supplies you have if it is working well. then reset cmos.
then if it would not power on, your motherboard maybe a deadset (meaning dead/unusable).
Mar 12, 2008 | Computers & Internet
No display on monitor
Can be a problem with any of the components.
Do the power supply, cpu fan and disks start to spin after power up?
Does the PC speaker sounds a sequence of beeps? Can you identify a pattern, like 3 short beeps indicates a memory problem.
Keep posting so we can zoom in on the problem.
Dec 28, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
