Question about HP Computers & Internet
On startup the hard drive makes continuous beeping sound and small orange light comes on
    Scholar:
  • 96 Answers
Your hearing the motherboard beeps, Check the connection of your RAM, Cards, and look to see if any keys are pressing down on your keyboard this will cause a beeping sound also, however make sure nothing is loose. and power it up.
I hope this helped
Posted on Sep 07, 2009
  • 215 Answers
Its not Hard Drive that makes beeping sound its your mainboard. Check in Bios (if possible) that HD is recognised properly. Disconnect HD form computer and then start computer without HD to see wheather the problem is still there. If not, connect another HD (preferably not more than 40 GB) and use a new IDE cable if applicable. Some HP PCs record in Bios their original HD serial number preventing replacement of HD. In worst case the HD controller on Mainboard is not working properly or may be defected.
Continuous beep motherboard will not boot
check the battery for the mother board memory. flat battery can make it no startup. also if that is fine remover the hard drive lead and turn on if it comes on then the hard drive is causing the fault. do same with rom's.
Mar 24, 2014 | HP ECS ACER 946GZT-AM V1.0 SOCKET- LGA775...
Dell studio 1745 wont boot
Look like you might have a display problem...
It is hard to see if you do not have any image on the laptop
If you have another monitor try plugging it in the out display port of the computer to see if you have a visual display on it
Jan 30, 2013 | Dell Studio 1745 (884116033233) PC...
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
I have a P4M800PRO M V1.0A. I have removed all RAM and not getting any beeps. I have disconnected HDD and Video Card and no beeps. Have cleared CMOS and no beeps, replaced Motherboard Battery and no beeps....
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
May 28, 2011 | EliteGroup P4M800PRO-M Motherboard
My desktop has an orange light no beep sounds when starting it won't boot up the back where ethernet plug goes is orange too the fan makes a burning smell also
Orange light usually means the harddrive or computer is processing and loading, But it can also mean that there is a problem with the hard drive. Start your computer and wait. If you see orange light it means its working to boot up, it might take a while, you might see your screen black for a while but eventually will work.
To fix this problem you need to upgrade more hard drive space, RAM memory and processor speed
Nowadays a computer should have a minimum of 2GB of RAM memory, at least 120GB of Space, and about 2.0Ghz of processing speed.
You can also buy great refurbished computers which are cheaper. Most of them come with 4GB of RAM memory, 250GB HD Space and 2.5Ghz processing speed.
May 24, 2011 | Dell Computers & Internet
In My APC UPS, continuous beep sound is coming with simultaneous Orange and Green lights are appearing
Unfortunately that signals an internal fault with the UPS and it requires immediate replacement / repair. Do not continue to use the UPS at all.
Mar 01, 2010 | APC (BE500U-WEB) (BE500UWEB) UPS System
I turn on my ps3 it comes on but i get no icons only a black screen
Try reseting your display. To do this turn your ps3 off if it isnt already, turn it back on and continue to hold the power button until you hear the beeps. It should reset your display if that is the problem.
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Monitor not responding to computer
better check the continuity of you cables/connectors.
May 28, 2009 | E-Machines eMachines Desktop PC
Lacie 250 GB harddrive
Lacie Porsche drives in my experience or infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. Hope this helps.
Aug 24, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Computers & Internet Logo
371 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
