Question about Element Electronics FLX3210 32 in. LCD TV
The TV picture blacks out from time to time
For a period of time the TV picture was blacking out from time to time and I would have to wait for about 20 to 30 minutes for the picture to return. I am unable to view a picture at all on the tv now. The power comes on but there is no picture at all.
  • juanbran Sep 07, 2009
    Yes i do have sound, but the picture cuts on for a wh
    Top Expert:
  • Element Elec... Master
  • 14,553 Answers
Do you have sound? let me know and I will have some suggestions for you.
SD TECH
Posted on Sep 07, 2009
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
When watching satellite or dvd the picture is black and white but i still get the blue screen and the tv setup menu has color. is it broken or fixable?
There is a cable which controls the colour on some televisions. If this cable is removed from the television the picture will go black and white. Chances are it has been knocked out by accident or it has just worked its way out over a period of time. Either way try to locate it and put it firmly back in place.
Nov 12, 2009 | Samsung TX-R2435 TV
Sony hd 55 inch tv-picture blacks out periodically, sound is ok.
The component board may be going out depending on what style type TV it is.
Nov 01, 2017 | Sony Grand WEGA KDF-55XS955 55" Rear...
The lower half of the screen is a black box on one channel
Check your closed-captioning settings. You probably have it set for "text". Make sure you turn captioning off and the problem should clear up.
Feb 12, 2009 | Recoton Advent Advent Q2035A 20" TV
Picture stays on black
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 03, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Element Electronics FLX3210 32 in. LCD TV Logo
56 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
