Question about The Times Case Corporation Tractors International Harvestor
I have a case 4210 farm tractor and need to know what the best type of hydraulic fluid to use would be ??????
  • The Times Master
  • 3,519 Answers
Older case machines used a fluid identified as TCH (Torque Converter Hydraulic) for both the transmission and the hydraulic system. It's not readily available so has been replaced by default by separate products. Hydraulic fluid for the cylinder system, and transmission fluid for the torque converter. I'm currently using NAPA TDH with no problems.
Posted on Sep 08, 2009
Wat hydraulic fluid do i use for my ford tractor 6700 modelEC215 serial number B364256
First, whatever you buy be sure it is Transmission/hydraulic fluid not just hydraulic oil. The hydraulic and trans oil are the same oil. John Deere trans fluid will work, Case IH. Tractor supply has a fluid that works good, Traveller Trans/Hydraulic Renew. It is for older tractors.
Nov 14, 2016 | Ford Garden
Anyone have auxiliary hydraulics layout particularly where/how its plumbed into control valve
PDF]2013 Skid Steer Loader Parts - Tractorpartsasap.net - All ...
www.tractorpartsasap.net/.../2013_Skid-Steer-Loader_Parts-Catalog.pdf
Auxiliary Heaters . ... Hydraulic Lift Cylinder . .... Service Manual - Tells you how to take the skid steer apart, how to fix it, and how to put it back together ... in the serious repairs or restoration, you need the shop service manual; It can give you many ...Bobcat. 520, 530, 533. 122571. $48.00. Bobcat. 500, 600, 610. 122521.Missing: layout ‎plumbed ‎into
[PDF]PARTS REFERENCE GUIDE - Service Motor Company
servicemotor.com/catalogs/PM-8490.pdf
HITCH PARTS. 125. HYDRAULIC PARTS ... Find the same heavy-duty quality builtinto Case IH batteries for your truck ... lawn and garden tractor, Case IH has the ... Whether it's off-road, lawn and garden, automotive, or marine application, look ...... 12 Gauge. Aux. Lead, 3/8" Eye with B- Splice 12". ZQC708101. 4 Gauge.Missing: layout ‎plumbed ‎1977 ‎clark ‎520
Massey Ferguson Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages9/
What hydraulic fluid is needed for a Massey Ferguson 390 · MF135 Selling ...... Hydraulics quit working after installing Aux Hydraulic control valve. MF 135 lift
Case Farm Tractor Parts and Manuals - Yesterday's Tractors
Dec 12, 2015 | Garden
I have a 4310. The three point lifts only under high rpm and won't lift any weight at all. Cleaned screen and replaced suction and trans filters. Still have problem.
A 4310s 3-pt should be able to lift approx. 1-ton at 24inches on the 3-pt lifting arm. I thought there was a hydraulic reservoir and a transmission reservoir and it is not uncommon to put the wrong fluid in one of those You might check that transmission fluid didn't get in the hydraulic tank.
May 16, 2012 | John Deere Seat 4210 4310 4410 4510 4610...
PtO will not engage on cub cadet 1000
It would be helpful if I knew whether it was working and quit or has never worked. At any rate it has of course a live PTO on it (not dependent on the clutch to engage-disengage it). Check your linkage, make sure nothing has come loose and not moving the travel rod. Secondly some models have a hydraulic fluid compartment that is used for the PTO alone, check to see if this is the case and if so check fluid levels. Back to linkage, the engage mechanism is usually a lever of some type that moves a valve body and lets hydraulic flow under extreme and engage s set of input and output clutches together. If your engage mechanism is a magnetic clutch, check for bad wiring and burnt fuses. If it is a fuse replace with the same value as already in the harness. If the new fuse flows don't do like me and put a larger fuse in it, though that will show what wires are involved with the clutch engagement it also shows the wires to be replaced. Check wiring for ***** wires or wires worn and touching metal parts and grounding out.Back to Hydraulics again, unless you've loaded the PTO hard enough to burn the clutches out (which I doubt very much) it can only be that fluid is not getting to the clutches. Chances that there is a problem inside the tractor with the valve body are slim but possible. Most PTO that just quit are caused by linkage problems or low Hydraulic fluid. Check all the above, I believe you will find your problem lies somewhere in what I have explained. I farmed for 30 years and we ran from 140 -250 HP tractors and if a PTO went out it was usually linkage or low Hydraulic Fluid. Hope this helps, don't want to miss a crop over a PTO!Col. Dana Gillespie TSM
Apr 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
2090 case trasmission problems
That's because you have two separate pumps controlling each. My best advice is to get a farm mechanic to take a look...it may be a simple seal to a need for a rebuilt pump. www.nyagparts.com
Jun 01, 2010 | RTO Case W14 1570 2090 2290 2294 2590 3594...
I have a Ford 3500 backhoe year is mid 70's. I need to replace the transmission fluid. Any idea what tyoe of fluid?
Officially, it's listed as M2C53A trans & hydraulic oil. Hope you can track down an equivalent where you are
Apr 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
The Times Case Corporation Tractors International Harvestor Logo
1,400 people viewed this question
Top The Times Toys Experts
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
