Question about Lexmark X7675 Wireless All-in-One Printer
Set up a desk top USB and a notebook wireless
I have a desk top computer also a notebook I have Verizon dsl on my Desk computer how can I set up my notebook
I would suggest getting a wireless router. one that supports the security on your laptop wireless card...then you can still hook up wired on the desktop and you can set up the wireless security and connect wireless to your laptop.
Nov 05, 2010 | Computers & Internet
Where do hook up wireless. I have dell desk top.
Hi and welcome to FixYa,
Almost always, wireless mouse makes use of the USB port to connect its base/receiver. Depending on the exact model of the Dell desktop, there would normally be USB ports at the rear of the computer. Some others have 2 USB ports at the front or side.
Good luck and thank you for asking FixYa.
Oct 22, 2009 | HP Wireless Optical Mouse
Wireless not getting to my notebook
I have had the same happen on my laptop, some computers don't have a wireless network card in them so you need to buy one. All you need to buy is a Wireless USB Adapter. They are around (but no higher than) $50.00. Just buy a "D Link Wireless G USB Adapter DWA-110" For $50.00.
Oct 17, 2009 | D-Link DIR-628 Wireless Router
Help setting up my home network.
If your printer only has a usb cord than u will want to hook it up to one of your pc's and set it up as a shared network printer. If it has an ethernet port you can hook it up directly to a router or switch.
PS to set your printer as shared goto ControlPanel > Printers > Right click on your printer > Click Sharing... Set it up to have a name you'll reconize and you should be good togo.
May 23, 2009 | D-Link AirPlus Xtreme® G DI-624 Wireless...
DESK TOP TO WIRELESS CONNECTION
First make sure you have the correct drivers installed, go to the Belkin website to get the latest drivers for your device.
Next make sure that your router is set to broadcast, and that is in Wireless G mode. You can find that information at the router manufacturers website.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Mouse V450 shipped with new Dell Desk top does not work reliably
It should be good up to 30 feet, whatever the setup. You might try plugging the send/receiver into a front port to see if that helps.
I usually open Device Manager, open each USB device and set the power to stay on, (not "turn off this device to save power"). That way, sleep mode won't cause you to lose contact with the mouse. Or just disable sleep mode.
May 18, 2017 | Logitech V450 Laser Cordless Notebook...
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Can not connect another desk top to wireless router
the link below will show you how to work on the wireless settings of your router and how to connect multiple wireless computers in a single network.
Setting up your Linksys router to have wireless security.
hope this helps, if you have other questions just let me know.
Nov 03, 2008 | Linksys WRT160N Wireless Router
Usb adapter
if the router is already set up the usb dongle software will need to be used to connect to the router to allow a connection without the need for a cable as the dongle will see the wireless signal
Aug 31, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Want to run a desktop and a laptop wireless
You need to get a wireless adapter for the desktop, either one that connects by USB or that goes inside as a PCI card. USB is easier.
Jan 18, 2008 | Medion MD 40812 Notebook
Lexmark X7675 Wireless All-in-One Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
