Question about Hitachi NR83AA3 3 1/4" Clipped Head Framing Nailer
Need to know size nail that it shoots and do you have new lables for the gun
  • David Ford
    David Ford May 11, 2010
    what is the exact brand and model number the header lists one but your question doesn't let me know and i will see what I can find.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
This gun takes 2"-3 1/4" .113" - .131" Paper striped 34 degree clipped head nails.
This is the Tool Card provided by Hitachi. Follow link:
http://www.hitachipowertools.com/product/files/pneumatics/framing_nailers/NR83AA3toolcard.pdf
Posted on Sep 14, 2009
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
The nail gun will not shoot
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
Oct 18, 2012 | Arrow ET200 Electric Brad Nail Gun
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
My bostitch bt200 recently will not shoot 2 inch nails, it seems to be to tight inside the holder
I have a bostich that takes only the "ay" nails, the "ax" nails won't fit and I think there is one other size, all wire gauge sizes, the "ay" are the smallest. Check it out.
Jul 17, 2010 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
Wher can I purchase a replacement circut board for an Arrow ET200 Eletric Nail Gun. What I have is an ET200 - 110v Rev.2 I would like to purchase on line.
Do you still need this? I have a good board from my ET200. I dropped it, and the piece that keeps the nail driver steady when it shoots in & out broke off. However, the gun still functions fine. Let me know.
Oct 09, 2009 | Arrow ET200 Electric Brad Nail Gun
MY NAIL NOTIS SHOOTING AND BENDING THE NAIL INSIDE THE GUN
you have a problem with the nose or the driver. I would also check for a jammed nail in the nose assembly. let me know what the model number is and I will try and find a breakdown for you.
Sep 18, 2009 | Stanley Bostitch Coil Framing Nailer
Need to know the brand of nails that work with this nailer
brand does'nt matter its the lenght and more inportant is the gauge if its shooting two nails than you are most likely using the wrong gauge example of gauges:16mm 18 mm ect. look on gun it should specify which gauge to use
Apr 30, 2009 | Tools & Hardware - Others
Hitachi NR83AA3 3 1/4" Clipped Head Framing Nailer Logo
109 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
