Question about GE Security Simon 3 Wireless Home Security System
A tec installed a ge alarm system in my home. he spliced into my existing phone jack. Coming from my alarm is a black and white wire. the wires from the wall have been barretted together into two bundles,going to the alarm. I have to change the jack where do i hook the black and white wires too?
  • 1 more comment
  • l_terry Sep 07, 2009
    I do not have a Rj31x jack or this would be easy. As I stated he spliced inot my existing old phone jack..
    The jack i have is old that is why i am changing it but I am not using the jack you talked about I am using an ordinary jack again... it is already set up for it as the tec simply spliced into my old jadk...see original message
    the jack i have is old and not the R3J1X. see original problem
  • 3,741 Answers
The jack you are talking about to which the phone alarm system wires are to be connected is called ------ RJ31X jack ----------- this is the direct link for the manual click the link directly http://safemanuals.com/user-guide-instructions-owner-manual/GE%20INTERLOGIX/SIMON%203-_E on page number 3 of manual its listed.after click on the link click download option so the manual will get downloaded.then see page number 3 all instructions with diagram is shown properly. ----------------- if you dont want to down load the manual and want to check all the connections directly ,instantly just click this another link directly and check out all the clear instructions http://www.systemswebstore.com/faqfiles/alarm_system_phone_connection.htm ---------- Note:in some jacks instead of white wire there is yellow wire.so yellow wire connection and white wire connection is same. this will help. ------ thanks.please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 07, 2009
What are the wire colors for a 2006 chrysler pacifica tailight harness?
The wire colors should be Yellow, Black, White and Green. Do not cut or splice anything into this harness. Use the trailer lights Tap connector that is already in the harness. It is located in the left frame rail near the rear bumper. The converter is a plug and play operation. No splicing is needed. Simply unplug the harness at the Tap connector and plug the converter T plug in series with the existing harness.
Jun 20, 2017 | Chrysler Cars & Trucks
Ge timer 15350 110 4 wires 4 post have 2 white on post 1 1 bk on post 2 0 wires on post 3 1 bk on post 4 2 grounds to the box pump will work manually timer will not work
Unknown if this is new installation, or existing install that stopped working.
Copy following link for wiring diagram showing GE 15350 timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Look at terminal labels, should be L 1 X and 2
Power coming from breaker should be 120Volt Black Hot wire, and White neutral wire.
Cable going to Load should be Black and White.
White wires should be on terminal X
Black Hot should connect to terminals L and 1
Black to Load should connect to terminal 2
If your timer looks different, repost question with link to photo on flickr
If timer stopped working:
GE15350 timer is 120 volt timer made by Tork.
It uses P47 trippers, and Tork 101 clock motor.
Jul 04, 2012 | Hardware & Accessories
How to splice samsung galaxy s cell phone car charger to wall charger
you should just do white to white and ref to red. just so you should know that ac chargers have a special crossover that the phone knows it is charging not usb' ing to a computer so you may get message on the phone to go into usb mode...just hot home and you well be fine
Apr 02, 2012 | Samsung Galaxy S 4G Cell Phone
I need installation guide for Viper 5000
Identify the primary wiring harness--it will have 12 wires, labeled as H1/1 through H1/12. The colors of the wires are red/white, red, brown, yellow, black, violet, blue, green, black/white, white/blue, white and orange. Locate this harness and get ready to wire it into your car's electrical system.
Locate the H1/1 wire on the primary wiring harness. This is the red-and-white wire. Connect the wire to the trunk release button on your automobile. You should be able to loosen a screw on the backside of the trunk release button, allowing you to insert the wire along with the original trunk release wire, before tightening the screw back down. This allows your Viper 5000 car alarm remote to open the trunk of your car.
Find the H1/2 wire, which is colored red. This wire is the primary input for the Viper 5000 car alarm. Remove the fuse from the wire before connecting. There are two options for where to connect the red wire. You can connect the wire directly to the positive power terminal on your car battery, or you can open the car ignition and splice the wire into the wire that supplies 12V power to the ignition. To do this, use your wire strippers to remove a small amount of insulation from the ignition wire. Splice in the red wire from the Viper 5000 and then wrap the connection with electrical tape.
Connect the brown wire on the Viper 5000 car alarm, identified as H1/3. Connect the brown wire directly to the red wire on the Avenger siren and mount the siren under the hood of your car. Connect the black wire of the siren directly to a metal section on the car body. The brown wire supplies power to the siren whenever the alarm determine it is needed. The siren's black wire serves as a ground for the current.
Take the yellow H1/4 wire on the primary wiring harness of your Viper 5000 car alarm. Connect the yellow wire directly to the positive (+) 12V ignition wire. If you chose to connect the red H1/2 wire to the ignition, you can connect this one at the same time. It is important for the yellow wire to have a full 12 volts of electricity when the car's key is turned to the on position. Check the 12V ignition wire carefully to make sure there are no nicks, cuts or other problems that could cause the current to short.
Prepare to install the ground for the Viper 5000 car alarm by looking under the hood or body of the car for a bolt. Find a factory-installed boat that does not have any other ground wires leading to it. Remove the bolt from the bolt hole. If there is any paint on the metal around the bolt hole, scrape it off with a razor blade. Find the black H1/5 cable on the wiring harness and place the ring terminal at the end of the wire onto the bolt. Then place the bolt back into its original position. The alarm system is now grounded to the car chassis.
Set up the door trigger input. Find the violet-colored wire labeled H1/6 and connect it to any existing wiring that has an active 12V circuit whenever the doors are open. The wires for the dome lights are often the best place for this connection. Carefully strip a small amount of insulation from the dome light wire and from the tip of the violet wire. Wrap the copper of the violet wire tightly around the copper of the dome light wire, then seal the two together with electrical tape.
Find the blue wire marked H1/7. Connect this wire to sensor pins in either the hood or the trunk of your car. This allows the Viper 5000 car alarm to detect if someone is trying to break into these areas, and to instantly sound the alarm to announce the presence of an intruder. Simply use a screwdriver to attach the blue wires to a standard sensor pin.
Connect the negative door trigger input to the Viper 5000 car alarm. This is the green wire identified as H1/8. Similar to how the door trigger input (H1/6) was connected to the wire running from the 12V power source to the dome lights, the negative door trigger will be used on the opposite side of that circuit. The negative current typically passes into the wire that runs from the dome light back to the door switch. Splice the door trigger input (H1/8) into this wire at any point between the door switch and the light.
Establish a connection with the high current output from the dome light supervision relay. Identify the black and white wire labeled as H1/9. Plug the end of this wire directly into the circuit for the vehicle dome light. Expose the dome light circuit by opening the light compartment, the same as you would when changing bulbs. Once the circuit is visible, locate the plug port and plug the black and white wire from your Viper 5000 car alarm directly into the port.
Skip the white-and-blue wire labeled H1/10. This wire is used as a Channel 3 output and is not needed unless you install extra devices that require it. For the time being, just make sure there is no exposed copper at the end of the wire and push it out of the way. If there is copper exposed on the wire, wrap it with electrical tape so that it will be insulated and protected.
Hook up the output signal to make the parking lights flash. Use the white H1/11 wire for this purpose. Remove a small section of insulation from the end of the white wire using a pair of wire strippers. Also remove a small amount of insulation from the wire that connects the parking light relay switch to the parking light bulb relay. Be careful not to cut all the way through the wire. Twist the wires together so that the white wire is connected to the light relay wire, then seal the connection with electrical tape.
Ground the Viper 5000 car alarm when armed using the orange wire marked H1/12. Find a factory bolt on the body of your automobile that does not have any other components already using it for a ground. Under the hood or under the body of the vehicle are ideal places to locate these bolts. Scrape away any paint that may be under the bolt head and use the bolt to fasten the metal ring at the end of the orange wire to the body of the car. Your Viper alarm is now grounded to the vehicle whenever it is armed.
Test your alarm system. Your Viper 5000 should now be able to unlock your doors, light the inside of the car and prevent theft of your vehicle. Test the features of the Viper 5000 car alarm to make sure that all components are working to your satisfaction.
Sep 23, 2011 | GPS
I'm installing 2 phone jacks in my newly remodeled home. We are supposed to have one phone line. Each of the boxes with phone wires in them has two cables coming out of it. In the first box, the one cable...
Pity that whoever did your remodel didn't give you a floor plan. In new construction, we make everything go to a central point. Old style was to loop everything through. It would be easy to tell, because you'd see the loops.
If you want to do this yourself, and save some money, give this a try.
The color code is that the green/red/black/yellow go to the jack. Hook all 4 wires (8 because you're going to hook both cables together to a jack) to the jack. Then, down the road, when someone has to add a second line they won't have to open this back up again. When it comes to the paired cable, look at the wires. One of the wires has more white than blue (White/Blue lead) and one has more Blue that white (blue/white lead) and so forth. You're going to be working with the blue pairs and the orange pairs, and spare out the green and brown pairs.
Strip the 4 remaining wires (the ends so they can go on the screw terminals) and connect them as follows:
White/Blue to Green Blue/White to Red White/Orange to Black Orange/White to Yellow.
If you're using Insulation displacement jack (the kind with caps where you push the wires into the slots), STOP! You're going to need more parts.
Mar 31, 2010 | Lands Phones
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
Removed alarm system; now phone won't work
In the alarm system there was a jack called an RJ31X. This jack is suposed to have the line run from the teleco interface to it and then back out to the rest of the house(except for DSL, it stays ir front of the alarm jack). When the alarm jack was cut out the line bridge was eliminated. To make the line active find the wire that went to the alarm jack and and connect the red wire to the yellow wire and the green wire to the black wire. that should pass the line through to the remainder of the jacks in the house.
Oct 13, 2009 | Lands Phones
I want to replace dimmer switch with standard switch
the two black wires spliced are Live wires ( same value as RED) the other single black is the return. The two twisted blacks from the wall go into ther active hole of the new switch and the single into the return. No third wire for earth is needed
Jul 27, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
Telephone disconnected from first alert professional alarm system
The phone wires run from directly from the telephone company connection to the alarm on the red and green. They return on the other two wires. These wires are hooked to your home phones. That's the UL way to do it. The alarm is supposed to be the first device on the telephone line. You can just run a phone line to the alarm panel. There probably is a diagram inside the cabinet door or a phone jack very near the alarm.
Apr 11, 2009 | First Alert SA302 Dual System Smoke...
Can bose wires be splice?
My cat chewed my bose headphone wire in two. Can the wire be spliced back together?
Nov 09, 2008 | Bose in-ear headphones - Black with...
GE Security Simon 3 Wireless Home Security System Logo
388 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
