there are two 4"dia. washers on each side on the pivot point where the handle is attached to the base these washes have slots cut into them do these slots need to line up in any particular fashion when the handle assembly is reattached to the base?
do you know where I can get shop repair manual for this machice?
The brush wouldn't work when the selector switch was in carpet mode. Took the power head apart and...
(More)
The brush wouldn't work when the selector switch was in carpet mode. Took the power head apart and removed the motor. Everything o.k. in the power head. Checked and found that the neutural wire had pulled out of the connector, the connector was never crimped at the factory. What a day! Took 2 hours and a large pizza to get it done. Neutral wire was in the hose just below the handle. Reconnected the wire and crimped it, put everything back together. It works!!!!
brushes wotn spin,belt not broken,cog that drives the belt is not spinning.When I turn the brushes...
(More)
brushes wotn spin,belt not broken,cog that drives the belt is not spinning.When I turn the brushes manually I can occaisionally feel it grabbing for a a brief second.Could the motor be bad? Is there a way to test the motor.Tahnks
