Question about RTX Computers & Internet
Can not get the Steering cable out From Tansome
    Brigadier General:
  • 5,158 Answers
What is the device or vehicle you are working on ?
Posted on Sep 07, 2009
How do I remove steering cable from 40 hp Mercury outboard
Depending on your boat , you normally have to unbolt the engine then remove off the transom , with help or a crane etc ! First remove the steering link bar then undo the large nut on the steering cable then disconnect the battery and all other cables and control cables etc then unbolt the engine and lift up so you can remove the steering cable ! If any corrosion in the tube you must clesn out and grease before fitting new cable and all others in reverse order !!
Feb 24, 2015 | Boating
How do i rove the clock spring 2012 nissian par\th finder
remove clock spring in steering wheel.
step 1 , disconnect battery minus lug.
then defeat air bags as the FSM book directs,(or great danger waits)
BOOM
Battery disonn.folly 110. "under collateral damage"
quote
Whenever the negative battery cable is disconnected the following components will require resetting. The Idle Air Volume Learning, Steering Angle Sensor Neutral Position, Sunroof Memory Reset/Initialization, Automatic Drive Positioner System, Audio presets and Navigation. Use the CONSULT-III diagnostic tool, or equivalent to perform the required resets. As necessary, refer to Battery Reconnect/Relearn Procedures.
he automatic back door system, if equipped, must be initialized anytime the battery has been disconnected. Close the back door. Open the back door with the automatic open feature. Do not stop the process until the back door opens completely.
end .
begin:
  1. Disconnect the negative battery cable. (wait 30min)
  2. Disconnect the positive battery cable.
  3. Set the front wheels in the straight-ahead position.
  4. Remove the air bag module.
  1. Remove the steering wheel.
  2. Remove the column cover upper and lower.
  3. Disconnect wiper and washer switch connector. Then while pressing tabs, pull wiper and washer switch away from spiral cable to remove.
Disconnect lighting and turn signal switch connector. Then while pressing tabs, pull lighting and turn signal switch toward driver door to remove.
  1. Remove the screws. Then while pressing the tab, pull the spiral cable away from steering column assembly. CAUTION Do not disassemble spiral cable. Do not apply lubricant to the spiral cable.
  2. Disconnect the spiral cable connectors.
With the steering linkage disconnected, the spiral cable may snap by turning the steering wheel beyond the limited number of turns. The spiral cable can be turned counterclockwise about 2.5 turns from the neutral position.
end remove.
to install, read the FSM book
or login to alldata.com
the cars steering angle is lost in the process.
so.....?????
steering angle sensor calibration after installing spiral cable.
Jun 25, 2014 | 2002 Nissan Pathfinder
Husqvarna Rider 155 No steering Rear end of cable looks okay
The steering is fairly basic, a steering wheel that turns a steering shaft, on the end of the shaft is a sprocket, around the sprocket runs a short chain, on either end of the chain is a steel cable, both cables run to a quadrate at the underside of the engine, the r/h cable then goes the the l/h fixing and the l/h to the right, so either the locking screw on the steering wheel shaft has come loose and not turning the lower shaft, or the sprocket has sheered from the lower shaft, or the cables are not adjusted correctly, remove the cover on top of the chassis between you feet, you will then see the lower shaft, sprocket and chain, you should see the problem when the steering is turned.
Dec 22, 2012 | Garden
Boat steering cable
This steering is swedged at the factory and can not be separated. If you will remove one end. (Motor end works best) And slide a cut bicycle innertube down over the end and hose clamp it to the plastic covering, you can force some light oil into the steering.
If this doesn't work in a day or two, you need a new steering cable.
Jul 18, 2012 | Light Boating
Remove steering wheel from Sportcraft center console boat
Is your steering using the cable / pulley and springs, or has it the through the tube steering? If it's the later, undo the nut that holds the cable to the transom bracket, Then try and turn the motor, If the motor won't budge, the pivot is seized, If the motor moves, your cable is seized or the steering box needs help! How to remove your steering wheel, There will be a cover hiding the nut in the centre of the wheel!
Feb 15, 2012 | Boating
Now to install igintion switch
Removal & Installation The ignition switch or warning switch can be replaced without removing the steering lock assembly. The ignition switch is on the back of the assembly and the warning switch on the side.
  1. Disconnect the negative battery cable and insulate the terminal end.
CAUTION The air bag system must be disarmed before removing the steering wheel. Failure to do so may cause accidental deployment, property damage or personal injury.
  1. Remove the steering wheel and the steering column upper and lower covers.
  2. Remove the spiral cable assembly.
View of the steering lock and ignition switch assembly
  1. Remove the combination switch from the steering column.
  2. Remove steering column support nuts and lower the steering column.
  3. Disconnect the ignition switch wiring and interlock cable (if equipped).
  4. Remove the bolts that secure the steering lock and remove steering lock assembly.
To install:
  1. Install the steering lock assembly and secure with new shear type bolts.
  2. Connect the ignition switch wiring harness and the interlock cable.
  3. Raise the steering column and secure with mounting nuts.
  4. Install the spiral cable assembly.
  5. Install the combination switch, steering column covers, and the steering wheel.
  6. Connect the negative battery cable and enable the air bag system.
May 23, 2010 | 1997 Nissan Maxima
Stearing on my 4yo 60hp mercury outboard will not budge
if you have "rotary" or "rack and pinion" steering. what your dealing with is rust. 2 things you can do to test the steering system. (1) tilt engine all the way down using the trim an tilt system. On the engine, you will see a steering rod that is parallel to the transom. One side of the rod is connected to the engine(ignore that connection), the other side curves down and connects to the steering cable. Disconnect steering rod from cable by unscrewing the nut counter clockwise. Once you disconnect the steering rod from cable. Push steering rod forward towards bow swinging it out of the way. Engine is now free from boat steering system. “Testing the engine steering tube“ all you have to do is manually turn the engine port and starboard using your hands. If your able to turn engine, the problem is the boat steering system. which you can fix. If you can' turn the engine then the job will require the engine to be removed from boat and transom bracket rebuilt. Take it to a repair shop.(2) with the engine still disconnected from the boat steering system. Get in the boat and turn the steering wheel. A good steering system you should be able to turn the wheel with just a finger. If wheel does not turn, you have one of two problems. Bad cable or bad steering helm. I always tell my customer to change both as a kit as a safety issue. if you are trying to save money. pull cable from helm, turn wheel if it turns easy replace cable (keep cable don't throw it away you have to get it matched) if wheel still stuck replace helm.
Oct 31, 2009 | Boating
Installing Boat Steering Cable
The rack and pinion cable steering is fantastic unit adn super smooth.
Assuming you have the right length cable, you start fomr the engine end and work to the steering rack end.
You need to hook up the 'rod' end to the motor via the morse tube on the engine. The rod end of the cable goes thorugh the morse tube and attached to the motor on the other side.
Centralise the motor fore n aft, and then centralise the steering wheel. Now drop on the rack onto the steering pinion (the thing the wheel attaches to) and do up the four bolts.
Test the full range of movement. The unit should have come with instructions which are pretty clear on how to do this...
Sep 21, 2009 | Computers & Internet
Replace airbag on `92 honda accord
When an SRS cable reel assembly is removed and set aside during vehicle repairs, the cable reel may rotate inside the assembly so it is no longer centered. If the assembly is reinstalled with the reel off-center, the cable can break when the steering wheel is turned to full lock. The cable reel holding fixture locks the reel while the assembly is off the vehicle, keeping it centered for reinstallation.
CABLE REEL REMOVAL PROCEDURE
1. Follow the procedure in the appropriate service manual for disconnecting the battery, and removing the dashboard panels, steering column covers, airbag, and steering wheel.
^ Always install short connectors on the connectors for the driver's and passenger's (if so equipped) airbags.
^ Make sure the front wheels are pointed straight ahead before removing the steering wheel.
2. Verify that the cable reel is centered; the yellow gear tooth is lined up with the alignment mark on the cover. Install the cable reel holding fixture in the cable reel assembly as shown. Use a TORX T-10 wrench.
3. Disconnect the 6-P connector, then remove the cable reel assembly.
CABLE REEL INSTALLATION PROCEDURE
1. Verify that the front wheels are still pointed straight ahead.
2. Reinstall the cable reel assembly, and reconnect the 6-P connector.
3. Remove the cable reel holding fixture.
4. Follow the service manual procedure for reinstallation of the steering wheel, airbag, steering column covers, and dashboard covers.
5. Verify SRS operation as described in the service manual. Road test the vehicle.
^ If the steering wheel spoke angle is not correct, change it by adjusting the tie rod ends. Do not remove and reposition the steering wheel.
PARTS INFORMATION
Cable reel holding fixture:
For 1992-95 Civic and Ohio-produced 1992-95 Accord
P/N 77900-SPO-999, H/C 4733564
For 1991 Accord Wagon, 1992-95
Prelude, 1995 Odyssey and Japan-produced
1992-95 Accord
P/N 77900-SM5-999, H/C 4733572
WARRANTY CLAIM INFORMATION
Use the Flat Rate Manual information for the repair being performed.
Jan 28, 2009 | 1992 Honda Accord
Frozen steering on mariner 75
It sounds like your steering cable is rusted in the eng steering bracket or your cable has gone south (Rust) try some heat to free it up and if that dont work its time for a new cable
Oct 04, 2008 | Simrad 20187423 Teleflex Adapt Lf 3000...
Computers & Internet Logo
14 people viewed this question
Top RTX Computers & Internet Experts
Bill Eager
Computer Repairing
Computer Repairing
Are you a RTX Computer and Internet Expert? Answer questions, earn points and help others
