Question about LG WM-2277HW Front Load Washer
Washer smells bad
We purchased a new lg tromm and within a few moths it began to smell bad inside the washer..i have cleaned all seal and it still smells bad and makes the clothes smell bad,,not a happy lg owner
  • 5 more comments
  • Anonymous Dec 10, 2007
    We are having the same problem with the washer smelling bad. can anyone provide information on the class action lawsuit against lg for their washers.
    Smell is bad and we also have seen mold build up. We have tried everything and nothing seems to work. Went to the store were we purchased machine and they said several people have the same problem.
    LG needs to take care of this.
    I talked to customer service at LG they said you have to clean machine seal after every use. She said I should have read the owners manual before I purchased machine. These people are nuts.
  • Yukon1 Dec 17, 2007
    I had the same bad smell but after cleaning the seal with a cleaning spray that contains bleach, I now keep the door open and don't have any problems. Try it! -P
  • Anonymous Dec 22, 2007
    Leaving the door open does not work for us. Clothes often smell musty especially towels and facecloths. water pools in the dispensers also so after each use it needs to be emptied.
  • Anonymous Dec 29, 2007
    My clothes smell badly, the washer has an odor, the seal stays molding and I constantly have to clean it, and yet it is stained from the mold. The washer is one year old, and I am very very sorry we purchased it. I recommend not buying this washer.
  • Anonymous Mar 16, 2014
    lg tromm smelling of smoke
There is a door on the bottom og this machine, I opened the door to find a little spot, I placed a bowel under the spout and opened it, drained all of the liquid out and this problem stopped! I also ran the machine on hot water with bleach after I emptied this resevoir. How often you do laundry will determine how often you must empty it. For me, once every 6-8 months does the trick!
Posted on Feb 15, 2008
    Problem Solver:
  • 6 Answers
I'm a field tech, and have found the best way to remove smelly soap buildup is to run a normal wash on hot water setting. add 1 cup of automatic dishwashing detergent (ie cascade or simular) not the soap you use in the sink. you can add this directly into the tub and will ususlly only be needed once every 3- 4 months.
Also be sure to only use HE soap and start by useing about half of what is recommended on package.
Posted on Mar 02, 2008
    Problem Solver:
  • 8 Answers
A colleague had trouble with clothes smelling bad after washing them. Turned out it was due to using a low temperature wash all the time which allowed the build up of some nasty bacteria inside the machine. The manufacturer recommended he used a high temperature wash about once a week to keep it clear and it's been fine ever since. Just a high temperature (non-economy)wash, no need to add bleach.
Posted on Feb 26, 2008
    New Friend:
  • 60 Answers
It has nothing to do with the rubber seal you're using too much soap and softner and it's building up inside the tub. Run the hotest wash you have without any clothes in the unit and add a little bleach. If you see bubbles in the water when it's running that's excess soap you're washing out. Do it over and over until the water stays clear and then start using less soap. It only needs about a tablespoon for a full load.
Posted on Dec 20, 2007
I got my solution from someone on line as well, and believe me, it works. I had this same problem and was at my wit's end to try and fix it. What an awful smell. This was about a year and a half ago. I posted my problem and got many similar responses to the ones here. Leaving the door open absolutely does not solve the problem. I add either Lysol, Pine Sol or Mr. Clean to each load, and I haven't had a bit of musty smell since. I use dryer sheets so I put it in the 'softener' section when I start my load. Try it, really, it works and you won't have the problem again. It's a great solution to a really bad design. Good luck!
Posted on Mar 04, 2008
I use a a few tablespoons of non-chlorine bleach along with the soap in every load now - takes care of the smell problem. When I ran out of it - whew - my clothes reeked!
Posted on Feb 10, 2008
  • 9 Answers
I also have had issues with a bad smelling LG Tromm 2277 washer when we leave the door closed after using it. One note on the LG site mentions that soap/scum buildup on the washer drum can encourage (smelly) mold growth. They suggested running an empty wash load and then pause it after the water fills and add a hot tub cleaning product (Whirl Out - I got it at Lowe's) and restart the load. This stuff should help remove the soap scum and limit the smelly mold growth. My washer does not smell as bad after using it. I also have run an empty cycle with only bleach using the very hot sanitary load setting.
Posted on Jan 24, 2008
  • 51 Answers
Try leaving the door open when it is not in use. There is a class-action law suit on this problem.
Posted on Dec 09, 2007
2 Suggested Answers
  • 130 Answers
SOURCE: washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
Posted on May 03, 2009
I have an LG washer that smells like rotten clothes. My clothes come out smelling real bad. I checked inside and noticed that the rubber seal around the door is holding moldy rotton gunk. It's not self...
Run a cup each of baking soda and vineger thru a hot wash. Might have to do this a couple of time if smell really bad.
Take out the unit where the liquid soap, softner, etc goes and clean by hand.
Soak a cloth in vinegar and clean the inside of the rubber around the tub.
And finally DO NOT LEAVE THE DOOR CLOSED IF NOT IN USE.
Oct 31, 2009 | LG WM2688HWM TROMM SteamWasher
LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Jul 26, 2009 | LG WM-2277HW Front Load Washer
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer smells bad
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Musty stale smell
HI thanks for your question. ALL front load washers have the same problem.MY solution every wash use 1 cup of vinegar in time will solve the problem. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | LG WM1814CW Front Load Washer
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Mold Smell in front loading LG Tromm
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 15, 2007 | LG WM0642H
LG WM-2277HW Front Load Washer Logo
3,559 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
