Question about Jandy Ray Vac Pool Cleaner for Inground Concrete
Pool sweep just keeps going in circles. It doesn't go all over the pool anymore...just keeps going in about a 4' diameter circle.
3 Suggested Answers
  • 4 Answers
SOURCE: Runs in a small circle
A couple of things to check. 1. sometimes the hose at the back of the head will develop a small hole or crack where water will escape and cause the vac to run in circles.
2. if the head is getting old, you might have enough wear that the little wheels on the bottom stay mostly in one location, pushing in one directon.
Posted on May 16, 2009
ftw1952
  • 10319 Answers
SOURCE: goes in circles
you have a clogged line. disassemble and clean it very good
it should work fine after cleaning all ports out
Posted on May 25, 2010
How many gallons does a 15' round pool 35 deep have
Basic school maths Pi R Squared, but are you sure this pool is 35 FEET deep?
Pi, (3.142) x radius squared
the radius is half the diameter x itself, x depth. and then
There are 7.48 gallons in cubic foot
Your pool diameter is 15' diameter, so 7.5 radius. 7.5 x 7.5 is 56.25. Multiply that by the depth. Multiply that answer by 7.48 gallons
Area of Circle
May 25, 2016 | Pool & Spa
Why does my pool sweep go around in circles on one wheel and not pick up anything in a week?
make sure the ballast ball doesn't have any water in it if so replace also make sure little exhaust on back is pointed at 11 o clock
Mar 31, 2016 | Polaris VacSweep 280 Pool Cleaner with...
How do I design a 6 foot diameter circle for my garden?
drive a peg in the ground where you want the center of the circle to be
get a piece of string and make a loop at one enf big enough to fall over the peg
measure out 3 ft from that loop and tie a stake at that point
now pull the string until it is tight and where the peg hits the ground make a mark
move about a foot an make another mark keeping the string tight all the whole
repeat the process until you have done a complete circle
the marks will be the circumference of a 6 foot diameter circle
Oct 12, 2014 | Esschert Design USA Esschert Design...
How do you find the circumfrence of a circle?
If the circle is a drawing, you can measure the diameter and multiply by pi (3.14). The diameter is the widest crossing and goes through the circles center. If the circle is an object, you can wrap tape around it. Mark on the tape where it meets up with the start. Remove the tape, lay it flat and measure it.
May 08, 2014 | Computers & Internet
Circumference of 4 foot diameter circle
The circumference of any circle is pi (lowercase Greek letter pi) multiplied by the diameter. For a four-foot diameter circle the circumference is about 12 feet 7 inches.
Feb 24, 2014 | Mathsoft StudyWorks! Mathematics Deluxe...
What is circumference of 4 foot radius circle
Feb 24, 2014 | Mathsoft Computers & Internet
What is the circumference of 4 foot circle
Feb 24, 2014 | The Learning Company Achieve! Math &...
Phanton pool sweep just turns in a circle upside down
This definitely sounds like an issue with the pool cleaners hose. Look for a bend or kink near the connection between the hose and cleaner. If you notice one, try stretching the hose on a flat surface in the sun for several hours. If this doesnt work, you will probably have to replace the hose.
Apr 24, 2010 | Hayward Phantom Pool Cleaner Complete with...
Hayward pool cleaner just goes in circle
If these automatic pool cleaners are moving in circles, it is usually an obstruction in the connection hose. Check the hose to make sure that there are not any knots or kinks that might not be immediately visible. Also, check to make sure that you don't have a partial blockage in either the cord or the throat. You will also want to check the return to make sure it is not allowing too much water to get to the cleaner. You might need to adjust the rear tension flap. Too much tension could cause the cleaner to go in circles. Finally, make sure that the wings and shoes are properly installed.
Apr 03, 2009 | Hayward Navigator Pool Cleaner
Jandy Ray Vac Pool Cleaner for Inground Concrete Logo
233 people viewed this question
Top Jandy Garden Experts
Dennis Key
Dennis Key
john h
Are you a Jandy Garden Expert? Answer questions, earn points and help others
