Question about Ryobi Garden
Need to replace re-coil on 740 trimmer. Is this a pressed on bushing?
Black&decker electric corded weed eater not running at full speed
the thickness of the cord , the length of the cord will both affect the speed of the motor as it needs extra power to run the longer length or thicker cord
most trimmer motors use a bush at the end of the armature shaft and this is affected by the sap out of the grass and dries out
this causes excessive wear which allows the armature to touch the field winding shoes and "pole "out . This intereference slows down the speed of the machine as it is a short in the field current to the armature
If you have an accredited appliance repair shop that is good with trimmers they may be able to replace the bushes but generally it is a replacement trimmer as the fix
have it checked out anyway.
Sep 16, 2015 | Garden
How to stop trimmer line spool from spinning off
I bought a Shakespeare Push-n-Load 3 blade trimmer head at The Home Depot for about 26 dollars and picked up a pack of 12 replacement blades for another 7. Did a whole 3 acres worth of weed whacking and still didn't need to change the blades. I was also powering through some pretty thick bushes with ease. Highly recommended.
Apr 13, 2013 | Craftsman 25cc Gas Line Trimmer
How to install suspension bushes 1984 ford bronco 4x4
If you have leaf springs jack the truck and remove shackle plates and bushes. If you have coil springs remove the bars and the bushes may have to be pressed in and out.. If you have independent suspension you will have to remove the arms and press the bushes in and out.
Apr 01, 2013 | Cars & Trucks
How to replace a arm bushing
upper or lower bushing . these bushing need to be pressed out - pressed in . but have to take spindle asembely off - brake caliper off just hang out of way -be sure to put jack under lower a-arm before loosen nuts that take off spindle ***. (coil spring very dangerous if you dont do this) tie-rod end link loose .if not comfortable doing take to front end aligment shop to have done.
Nov 05, 2010 | 2001 Dodge Dakota
Trimmer keeps shutting off after 5 min of use, after i let it cool off for 5 min it will run for 5 min
the coil inside the trimmer is shorting out you may need a coil motor replace. check mannyssharpening.com
Mar 07, 2010 | Andis 04603 Hair Trimmer
My 90 740 volvo's right front tire is rubbing the strut. i got the right tire size and i got it aligned, the guy said i need a new bushing because it is still rubbing up againt the strut. where and which...
upper strut bushing will adjust that somewhat it sits just straight up from the strut sits in a cap you can see looking down at the wheel with the hood open you will see the top of you strut sticking up out of the fender.
Sep 10, 2009 | 1990 Volvo 740
1990 volvo 740 GL no fire or fuel
Try replacing your fuel pump relay,this controls this.The fuelpump relay is two relays in one unit.
Jun 29, 2009 | 1990 Volvo 740
Broken bearing or bushing ?
Try this site its called pats small engines
Jun 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Volvo 740(1990) i replaced my coil and change the battery, it started, then went 50 yards the it died and now it just turns over, but won`t start, is there anything else it could be? thanks
Many things can cause this on your 740. Fuel pump, fuel pump relay, rpm sensor, MAF sensor, radio suppression relay. I've never seen the coil fail on these era Volvo's, ever. And I've diagnosed at least 50 of these with stalling problems. Check the codes, and when it wont start, check for spark and fuel pressure, you're likely missing one of them.
Feb 25, 2009 | 1990 Volvo 740
Garden Logo
19 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
