Question about Dell Latitude D810 Notebook
Notebook will not start.
When you press the power button the caps lock light blinks for about three seconds. the blue antenna looking light also stays on solid for three seconds. the light go off and nothing happens. I plugged the ac cord in and the same thing happened. I took it apart and checked all the connections. I also checked the memory card to see if it was loose.
  • 742 Answers
Please check with dell service center. it could be a motherboard problem. or, try to remove the battery and plug the adapter directly on AC power.
Posted on Sep 07, 2009
Testimonial: "thanks for the fast response to my problem. I was afraid it might be the motherboard. your info was very helpful."
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
I have a problem with the remote control that is not working, I have taken it local technicians but nothing . My TV is in child lock so I need a remote for the tall big telefunken TV
Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
Feb 01, 2011 | Televison & Video
Blue screen after I have done system restore on compaq presario CQ60. I have tried F8 on start up to run in safe mode but nothing seems to starp the blue screen on start up now.
Welcome to FixYa
Dear user
Perform a Hard Reset first.
Disconnect devices including USB devices and media cards. Disconnect the AC power adapter, remove the battery Press and hold the power button 15 seconds . connect the power adapter -do not connect the battery- Press the Power button, Look for blinking LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Hope this helps...Thanks for Connecting FixYa...
Dec 04, 2010 | Compaq Presario Notebook
Sometimes when I press the starter button, my car with crank for a little bit, then won't start but the car is still on. I normally press the starter button again to turn off the car, then press it again....
These issues can both be solved through programming. The crank time needs to be extended and the door locks (may) need to be set to double pulse. Can you unlock the doors by pressing the unlock button twice within one second?
Please read all the way through to familiarize yourself with the process before beginning.
Let's try the programming; you will need the vehicle key and the remote. The control/programming switch is located in the antenna on the windshield.
Turn the key on then off; press and hold the control button on the antenna to select the menu. One honk of the horn/flash of the parking lights indicates menu one(1). Now, press and release the button five (5) times (door lock pulses), then press and hold the button. While holding the control button on the antenna, press the lock button on the remote once. You should hear two horn honks/flashes from the parking lights. The system is now set for double pulse unlock. DO NOT RELEASE THE CONTROL BUTTON.
We will now advance to the third menu; release the control button, immediately press and hold the control button. After three seconds the system will begin to advance to the next menu. You will hear two horn honks/flashes from the parking lights. Continue to hold the control button to advance to the third menu. You will hear three horn honks/flashes from the parking lights. Now, press and release the control button three times, then press and hold the control button. While holding the control button, press and release the lock button on the remote. You should hear two horn honks/flashes from the parking lights. Two flashes/horn honks is .8 seconds cranking time. Release control button. Turn ignition on to exit programming/learn routine. Test the system.
If after testing the system , you require a longer cranking time; re-enter the programming/learn routine, menu three, option three and press the lock button on the remote once to advance to one(1) second cranking time.
The programming/learn routine exits if the ignition is turn on, the control button is pressed too many times or there is no activity for 30 seconds.
Nov 28, 2010 | 1401 Remote Start/Keyless Entry System
My laptop will not turn on
Try another AC Adapter with the battery taken out of the laptop. If the light still blinks then that means the motherboard is bad and would need to be replaced.
Jun 01, 2010 | Compaq Evo N1020V PC Notebook
Blank screen on laptop
Sorry to hear you are having problems. I have had this same issue before with this particular model. The following solution works 90% of the time.Perform a hard reset as the first procedure.
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. Some HP Notebook PCs come with one stick of memory but have two memory slots. The problem could be that the stick of memory or one of the memory slots has a bad connection. The memory module compartment on most notebooks is located on the bottom of the case. The exact position varies by model. However, on some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
Use the following steps to remove and reseat the memory modules: Step 1 - Remove the electrical power To remove all power from the computer and prevent accidental damage to the electronic components, do the following:
  1. Turn off the computer by pressing and holding down the Power button for about 30 seconds.
  2. Unplug the AC adaptor from the notebook.
  3. Slide and hold the battery release latch to the unlock position.
  4. Use your finger to lift the battery up and out.
  • Remove the memory module cover on the bottom of the notebook .Loosen the compartment's retention screws and lift up and remove the memory compartment cover. Remove the memory modules from the memory slots To prevent damage to the memory module, grasp the memory module by the side edges. Do not touch the metal contacts.
    1 - Pull the retention clips away from sides of the memory module
    2 - Gently pull the module out of the memory module slot
  • Reseat the memory module by holding module at a 45-degree angle, and pressing it firmly into the memory slot until it is seated.
    After reseating the memory module, replace the cover over the memory compartment before restarting the computer
    Hope this helps FiYa! If you find this solution helpful, please take a moment to leave us some feedback.
    Thank You!
    May 12, 2010 | HP Pavilion dv9000z Notebook
    Will not boot
    click here to find the details.
    you may also like to click here
    Oct 02, 2009 | Dell Inspiron 1501 Notebook
    Fujitsu Plasmavision PDS-4233
    HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
    Aug 30, 2008 | Fujitsu Televison & Video
    Dell Latitude D810 Notebook Logo
    261 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
