Question about Garden
Mower won't start after being in storage after 6 months. Put new battery and spark plug in. Looks like a spring might be missing coming off of the carburator.
  • jgseeger Sep 09, 2009
    I was able to get the mower running, but now it only runs with the choke wide open. How do I adjust the carburator or throttle to keep it going?
  • 474 Answers
Your carb is probibly gummed up. remve the bowl and cln
Posted on Sep 07, 2009
Testimonial: "I will give it a shot tomorrow."
Hu700f won't start
My huskuvarn will not start put a new carburetor and a magnitude coil on it it is brand new and will not start it is a 700f husqvarna any suggestions on it plus like I said a new coil and it is not sparking and not starting please help me out
Feb 18, 2013 | Husqvarna HU700F 160cc Gas 22-in 3-in-1...
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Last time used 18 months ago, ran good, no problems. Tried to start it and it won't go...So I checked oil level..(good) removed the fuel bowl replaced old fuel with new fuel all looks well and cle
heat the spark plug for a few minutes then put back in the engine. sometimes works when you not used engine in a long time. it will take a good few goes to get the old fuel out of the carb, the heat helps burn old fuel.
Jul 09, 2017 | Motorcycles
Won't start. Drained old fuel and added fresh; cleaned in-tank fuel filter; cleaned plug. Still won't start
i would take the plug out and and the spark plug wire on the plug and try cranking it over and make the plug is firing if there is no fire then the ignition coil is dead but if you have fire then its a carb problem rarely ever a timing considering most mowers are timed with key ways which prevent them from jumping time.but if you have fire your good their but my overall suggestion is to rebuild the carb and swap out the spark plug if the mower has set for a period of 6 months or longer.
Aug 26, 2011 | Garden
My mother-in-law put gasoline in the oil fill spout. tiller sat like this for 6 months. was not started. I have drained oil/gas, but still can't get to start
This is a new for me. I suspect that removing the spark plug to put a squirt or two of engine oil on top of piston to lubricate and raise the compression would be a good start. Insure that the spark plug is clean and dry and sparking when pulling the starter rope. Reinstall spark plug and try again. If no success remove air cleaner and with choke open and throttle open give a short squirt (1/2 second only) of ether in intake orfice and start right away. If engine wants to fire the carb. is plugged up with old fuel and will most likely need to be cleaned our rebuilt. Note: 6 months in storage with the fuel not drained or at least stabilized is a major cause of small engines that will not start.
Feb 21, 2011 | Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
