Question about Asko T721 Electric Dryer
The drier is working but the water is not going into the collection container. It just sits in and around the condenser. It has been thoroughly cleaned according to the manual.
    Problem Solver:
  • 17 Answers
The problem is in the condensor. Keep cleaning it regularly. Make sure your drain hose runs downhill.
Posted on Mar 02, 2010
I got a Whirlpool AW Z 865 dryer. It is a condenser dryer and the water is not going up to the collecting bucket, but remains below and then leaks out and floods the floor when I open the little pull door...
I had a similar problem with a Whirlpool AWZ 8578 Tumble Dryer. The solution was to clean the fluff out of the rubber grommet in the drain hole under the left front of the condenser. Then the water from the condenser could run into the collection container underneath.
Nov 25, 2010 | Whirlpool Dryers
I have an indesit is70c condenser drier and it doesnt seem to be collecting all the water in the water container. some seems to make it into the container but then the rest just sits in the container...
To take the lid off, remove the two screws at the back and slide the lid backwards. If you try to lift the lid up, you will break the plastic catches. I learnt the hard way. If you do it correctly, it's easy.
At the back of the tray that holds the water container there is a small hole which allows access water to drain back down into the pump. Clean this hole(it will probably be full of fluff and hair). While you are there, there is two tubes at the back off the drier the thicker on of the two is the one that the access water drains into, make sure this is not split(mine was and I used self amalgamating tape on it to seal it again.) Replace lid, replace water collector, job done.
Jan 19, 2010 | Dryers
Zanussi tc470 condenser drier Red light is staying on even after the water container is emptied. switch appears to be faulty
excess water seems to be lodged in the drier and was drained out.There is a drain at the rear of the machine. I am concidering connecting a pipe here and draining permently to the outside.
Dec 28, 2009 | Dryers
Miele T358C dryer. water not being pumped out of the sump??
TRY THIS:
TRY THIS:
In some cases cleaning the condenser out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, it is normal for there to be some water in the tubes when you do this, you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier for air circulation; and empty the water container often or reconfigure your pluming arangement to reduce the water left in the container. The circuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later :?) DRRXR
TIP OF THE DAY--
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Feb 02, 2009 | Miele Novotronic T220 Electric Dryer
Dryer not heating up
I hate to tell you but get ready for more problems with this drier, it has a bad track record. In some cases cleaning the condensor out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, this is under the bottom panel at the front of the tumble dryer, you simply pull the panel down, undo the condenser and pull it out (it is normal for there to be some water in the tubes when you do this), you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier and empty the water container often. This curcuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later DRRXR
Feb 02, 2009 | Hotpoint Dryers
Asko T741 - Thermostat keeps cutting out
Ken from Mecheltec suggests removing condensate sump and pump assembly and servicing it. Clear condensate hoses from lint and debris then carefully reinstall assembly. You should be ok.
Oct 06, 2008 | Asko T741 Dryers
Refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Mar 11, 2008 | Refrigerators
Bosch classixx condenser drier
The problem is with the lower water tank float switch, it is stuck. Take off the right hand side panel (as you are facing the machine) at the bottom you will see a spring mechanism for the belt tension. Beside this there are 2 electrical connectors. Take them off and spray with wd40 or similar. Whilst off give the plastic box they fit 2 a light tap with a hammer to free the float switch. Reconnect and try. If this fails you can over-ride by leaving the left hand of the two plugs off. This will get your machine working but you will not have an indication as to when the water container needs emptying so you will need to remember.
Nov 30, 2007 | Bosch Axxis WTA4400 Dryers
My tumble drier no longer condenses! Water comes out the middle of the machine.
Hi LesleyB, I have just read your question on Fixya .com and I have the same problem with my dryer. I know your question was raised some time ago with no answer on Fixya...but I was wondering if you ever got to the bottom of the problem? Like I say I have the same model here in the UK and cannot find anyone who knows what the problem is (without charging me the earth to come look!) Hope you can help...Thanks Simon B, Manchester...UK
Sep 29, 2006 | Zanussi TC7114W Electric Dryer
Asko T721 Electric Dryer Logo
234 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
