Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Noisy fan in fridge
I have a new Mitsubishi fridge i have gone from and old manual defrost to a cyclic defrost and i am finding the noise from the fan loud and annoying
i have had a repair person a round to chk it and he says it is a normal sounding fan can you tell me is a fan in a cyclic defrost louder than a fan in a frost free and is there any way of making the fan quiter
    Problem Solver:
  • 8 Answers
Most likely to be a buildup of ice around the fan
Posted on Dec 18, 2007
  • henrygracer Apr 09, 2011
    I have a fisher paykell 2 door fridge. The fan suddenly started to shriek and then go quieter. Turned out to be ice buildup. I removed the back of the freezer compartment to access the fan, but probably the problem could have been solved byemptying the fridge,turning it off, for a while.,without disembling anything.
    Henry gracer
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
Fridge too warm: makes ice, does'nt dispense it: dispenses water warm
I know that it is new but this might be your problem
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Since it is new, you should have a warranty and I would see if a repairman can check it free of charge before attempting anything, I don't know your skill level with this type of machine but good luck and don't forget to rate this post, Have a Great Day!
Mar 23, 2008 | Maytag MZD2766G Side by Side Refrigerator
Can I simply defrost freezer to solve a grinding noise that stops when I open fridge doors and gets louder when I open freezer doors?
Not knowing the type of Refrigerator, frost-free or cyclic-defrost-
My opinion is, the noise may be generated from the Fan in the Freezer -compartment,
It is mostly situated in the freezer, behind a removable panel at the rear wall, The panel has a grill, or is slotted to allow the cold air to flow.
The fan may be worn out.
You may hear a grinding or squealing sound.
The fan-blade may be touching (striking) something,
The blade may have moved along its shaft and strikes the housing.
It may strike solid ice ,
the ice can form, if there is a fault with the Automatic-Defrost.
You need to confirm if the fan blade rotates freely.
Do you know how to do that?
K. AUS
Mar 11, 2015 | Refrigerators
Noisy Fridge
sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Apr 23, 2017 | Samsung RS2630SH Side by Side Refrigerator
Hi Fridge side fan was noise for 3 days and now
Hi I have same unit. Problem is the fridge circulator fan gradually ices up, becomes noisy and then stops when frozen up.
To fix quickly you need to remove all shelves drawers etc, then unfasten lower panel fixings and find the whole back is full of ice including the fan.
Remove panel , and de-ice fan etc until fan rotates freely. Replace and all will be OK.
Otherwise empty and defrost normally but be prepared for a long wait
Don't call an engineer he will just do same. Hope this helps
Mar 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
Kenmore Coldspot freezer too warm
Hope this helpout......
Jul 28, 2010 | Kenmore Refrigerators
Refrigerator won't get cold enough
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section . For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Kenmore Refrigerators
Whirlpool model ED5FHAXSLOO refrig 3 years old very noisy
If it is cooing fine, then the noise is probably your evaporator fan (the one inside your freezer). This can be cause by one of several things. The motor on this fan may be going bad, or, more likely, you may have a build up of ice around the blades that are touching the fan. This may be caused by a defrost circuit that has gone bad, or, the freezer may have been open alot lately and there is an excess of frost that hasn't melted away yet. If you can, manually defrost the freezer and see if it goes away. If it doesn't, it's probably the fan motor. If it does, and then comes back, it's probably the defrost circuit. Hope this helps!
Dec 06, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Fridge noise
  • Hissing and popping is normal on frost free refrigerators, it is the defrost heater.
  • Check that the refrigerator is level.
  • Check the drain pan.
  • Check the condensor fan.
  • Check the evaporator fan.
  • Inspect the compressor mounts.
plz rate this post
Jan 30, 2009 | Samsung RS2630WW Side by Side Refrigerator
Ariston Fridge not cooling - Frozen Coils
Try to check the noisy fan, slow rotation of fan can cause the icing evaporator. Unplug the unit and rotate the fan manually by your finger check if the fan is not misalign or not touching the fan frame. Or check if fan motor bearing is not worn out. Under charge of gas is also one of icing cause.
Feb 20, 2008 | Ariston Technologies CBC96 Wine Cooler...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
460 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
