Question about Texas Instruments TI-84 Plus Calculator
All keys in the 4th column enter a 6; press 3 displays 6
Pressing 9 key displays a 6; pressing 3 key displays a 6
I have reset the calculator but this did not fix it.
  • 3 Answers
If your batteries were allowed to deteriorate and leak acid into the unit, the acid residue may be shorting out the "6" key. This amounts to keeping it pressed all the time, even if the physical button is not pushed down or stuck.
To repair . . . you will need a tiny hex key wrench (smallest that Radio Shack carries), a small Phillips screwdriver, cotton swabs, and vinegar.
Before you begin, archive any programs you may want to save on the calculator, if possible. Then open the case: 1. Remove 6 case screws on back using tiny hex wrench. 2. Remove Phillips screw under main battery cover; this holds the backup battery cover in place, but also secures the case. 3. Gently pry the case apart. A pen knife inserted between the case halves and gently twisted may help, starting at the bottom edge (near keys, not screen) 4. Remove 2 small Phillips screws at the bottom edge of the foil panel. The foil will still be attached to the circuit board; gently lay it to the side but do not detach. 5. Remove 4 small Phillips screws from the circuit board. 6. Carefully lift the circuit board out of the remaining case. If you can leave the rubberized sheet and keys in the case, you won't have to worry about keys scattering and being replaced in the wrong locations on reassembly. 7. Examine the side of the circuit board that was next to the rubber pad. You will see metallic circles that correspond with the keys. Locate the circle that corresponds with the "6" key. 8. Using a cotton swab dipped in vinegar and blotted to nearly dry, gently scrub the "6" key contact. The goal is to remove any debris between the center and outer patterns in the contact. 9. Carefully dry the contact with a dry cotton swab. 10. Examine the inside of the case and other surfaces for any remaining residue and clean in a similar manner, avoiding too much friction and drying each surface carefully. 11. Reassemble the calculator (note, the 4 screws that go directly into the circuit board go into the holes outlined in gray/silver; if you use wrong screw hole, case screws will not go in). Also, end of foil sheet tucks under metal tabs at top of circuit board, near usb
Posted on Sep 19, 2010
  • mom-60 Sep 19, 2010
    (looks like there is a length limit . . . here is the rest)
    11. Reassemble the
    circuit board, near usb & AC connectors; tabs on sides at top of foil need
    to be carefully tucked in alongside board.
    12. Test calculator.
    If screen does not light, gently press the case halves together further
    and see if the "click" into place, then test again. If case was
    not fully snapped together, remember to gently tighter hex screws once case is
    snapped tightly closed.
    11. Reassemble the calculator (note, the 4 screws that go directly into the circuit board go into the holes outlined in gray/silver; if you use wrong screw hole, case screws will not go in). Also, end of foil sheet tucks under metal tabs at top of circuit board, near usb & AC connectors; tabs on sides at top of foil need to be carefully tucked in alongside board.
    12. Test calculator. If screen does not light, gently press the case halves together further and see if the "click" into place, then test again. If case was not fully snapped together, remember to gently tighter hex screws once case is snapped tightly closed.
  • 41 Answers
Does pressing the '6' key do nothing? If so, it sounds like the '6' key is stuck. Try repeatedly tapping on the '6' key to get it un-stuck.If that doesn't work, it's probably time to get a new calculator.
Posted on Sep 15, 2009
How do i calculate the standard deviation
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. you should be able to recognize what each variable means.
Oct 26, 2011 | Casio fx-300ES Calculator
Can you please help me on how to calculate mean, median, mode, standard deviation calculation on casio fx-991ms scientific calculator
This will show you how to do statistics (calculate average, standard deviation, regressions etc.) as to the mode and median refer to the definitions.
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Apr 19, 2011 | Casio FX-115ES Scientific Calculator
How to calculate standard deviation in casio fx 115es
Nov 12, 2010 | Casio FX-115ES Scientific Calculator
How do u find standard deviation using this calculator?
Oct 25, 2010 | Casio FX-115ES Scientific Calculator
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
How do you caculate standard form on a casio fx-83es calculator
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
Jun 10, 2010 | Casio fx-300ES Calculator
FX-115ES Scientific Calculator: how to do standard deviation...
May 16, 2010 | Casio FX-115ES Scientific Calculator
How to calculate the standard deviaition on the casio fx115es
Apr 05, 2010 | Casio FX-115ES Scientific Calculator
Standard deviation
I assume you know the theory. I will only show you the key strokes for 1-Var statistics.
Press the number corresponding to the variable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
Hope it gets you started
Oct 16, 2009 | Casio FX-115ES Scientific Calculator
Wrong key output displayed.
Have you ever dropped it? If so, there may be something wrong inside it and you may have to open it up and see. I am not much of a technition on the inside of the calculators, but check to see if any thing is busted or if there are any "loose wires". If not I suggest that you ask a professional.
May 13, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
166 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
