Question about LG Secret ? KF750 Cellular Phone
My touchscreen is not workinh especially from left to right
I really need help with this i resetted my phone and the touch screen still doesn't work so now i can even rest the correct time cuz it is not moving.... what should i do?
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
Memory full message
The unit may require a software update
goto http://www8.garmin.com/products/webupdater/
if that doesn't work you may need to do a master reset (you would loose any saved favorites and waypoints, saves etc)
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touchscreen when this message displays
  7. Touch Yes
  8. The device will automatically reset
(garmin.com/support/searchSupport)
Jun 13, 2011 | Garmin Nuvi 660 GPS Receiver
I have a samsung gt s5233 w edge and the touchscreen has failed. the left and right part of the screen is not functioning anymore. but when i press at the center, the right side of the screen activates....
check the conector of the touch, if the touchscreen connector is not connected properly just unconnect and connect properly ,if it does not work buy a touchscreen.
Mar 13, 2011 | Samsung Star GT-S5233 Cell Phone
LG GS290 touchscreen problem I have a LG GS290 and the touchscreen has partly frozen. It seems to shift everything to the right, so when you touch 1 it activates 3. Really really annoying as you can't...
Have same problem but only shifted 1 to right ie 2 = 3 and cant use left hand keys and cant re calibrate. Turning off for a while sometmes helps but problem returns
Dec 25, 2010 | LG Cell Phones
My phone is not able to touch on the right side. I try touching the screen on the right and it selects something on the left and u can't even recalibret it cause the right side don't work.
try factory resetting the phone, as calibration doesnt work, if this doesnt help the problem you will need to replace the touchscreen, expect to pay £25-£35 at a decent repair shop
Oct 23, 2010 | Cell Phones
My a1221 its very crazy, it don't understand the real position on the touchscreen, if pick a point, the screen get 8mm below, so if i pick near to the bottom of the screen ,it do nothing. it's like the...
I might be able to advice on how I find it best to use the touchscreen.
To answer the phone run your finger (or the stick that came with the phone) from left to right across the screen.
The same method applies to other operations on on the touch your finger from left to righth screen.
I discovered that it is of no use to press the icon, rather move your finger from left to right over the text that explains the operation, as when it is reminding you of something you have put in to be reminded of.
I use mine to remind me of doctors appoinments and to remind me of when I am to take my medecine.
Jun 14, 2010 | Cell Phones
660 touchscreen doesn't detect touching
Yes, the touchscreen is defective. Please see this link for more info on this probem:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 08, 2009 | Garmin Nuvi 660 GPS Receiver
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Touch sensitive screen not working
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
May 14, 2008 | LG KU990 Viewty
Touchscreen...
go to phones setting & reset it. master reset code is 4 times zero (0000). If code dosent work then u have to unlock ur phone by box called Cruiser. If this does not work ither ur touch screen is damage or the s/w is curropted. U have to flash it
Jan 10, 2008 | Sony Ericsson P910i Cellular Phone
LG Secret ? KF750 Cellular Phone Logo
81 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
