Hitachi LCD rear projection, 50VS69A, picture and sound disappeared and then the led of power, temp and lamp blinking successively and ended with lamp led on. What happened and how to fix it?Thanks!
  • 556 Answers
Buy yourself a lamp and install it. Most owners manuals have step by step instructions.
Posted on Sep 11, 2009
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Hitachie 42v715
The lamp is dead.The lamp in the tv now,been in used 1 1/2 or 2 years?The lamp life span is over.
May 16, 2010 | Hitachi 42V710 42" Rear Projection HDTV
My hitachi 50vs69a tv wont turn on and after afew blinking red li
Have you replaced the lamp? Unplug the set remove the lamp and see if it's blown
Sep 20, 2009 | Hitachi 50VS69 50" Projection HDTV
My Hitachi 50V710 has both indicator lights blinking and does not display any image. Temp LED and Lamp LED. But I hear the fan running and the lamp is the same I've always had. Whats wrong?
With both LED's flashing sounds like a bad lamp to me. Not uncommon for Hitachis LCD projections to have that symptom. Cjeck your owners manual for the light flash code. Good luck..
Jun 20, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Overheat led blinking
Did you ever get a answer to this question? I have a hitachi 50vs810 with the same problem. I found the same sensor "tokin ohd3-90m."
I ohmed across mine and it shows open. I then held my lighter under it and it stayed open. I suspect this part is bad so I tried jumping it out. No change. Still have the same blinking temp light.
So... in the end I don't know if I tested it right or not either. Good luck and let me know if you learned anything that can help me out.
Apr 09, 2008 | Hitachi 50VS810 50" Rear Projection HDTV
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
No picture
Symptom: LAMP Led Blinking Cause: Check the door lamp switch & lamp pwr switch, boss on the door or lamp assy may not close switch. apply tape to boss.
May 13, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
Electro Med Services...
