Most current AGP video cards are now 8X and they will still work with your motherboard but will just be limited to 4X. Trying to find a 4X might be time consuming whereas using an 8X downgraded to 4x would be comparatively easier and faster.
Additionally most Video cards will work under XP with the appropriate drivers but Vista has a limited list of compatible Video cards.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
All AGP based cards are backwards compatible, so an 8x card should operate at 4x 2x and 1x
however what is important is the voltage of your slot, you can tell by looking at the slot itself, the AGP slot may have a partition either 1/3 or 2/3rds down the slot, or may have no partition at all,
this slot partition is to prevent you from inserting a card of the wrong voltage.
If there is no partition in the AGP slot then the slot has a switchable voltage, and will automatically switch to the appropriate voltage, (on request from the graphics card AUTOMATIC)
so all you need to check is that the graphics card you buy has slots on the AGP interface that accomodate those on your board
according to the manual
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=413&areaid=2&LanID=0
This board has a 4x AGP slot
