Question about LG 30" Over the Range Microwave Hood with Glide & Cook Tray, LMV1645S
I have a LG above the stove microwave that doesnot heat anything
I have a LG 2cu ft above the stove microwave that does not heat anything on any setting. Everything else works fine except that it is useless unless it heats! The last thing that was cooked in it was 3 potatos for 10 minutes
  • LG Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
56wrtuj
Posted on Sep 30, 2010
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
What are the specs for GE JVM 1339BW002
All microwaves above the stove top are 30" wide . The only difference is the top to bottom measurement . Some are 15 1/2" in the back and some are more .
Feb 23, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Lg microwave over the stove will not heat up the food
Magnetron, the diode most use, or the large ac filter cap are all possible.
most people cannot test or even in some cases get at those
Dec 23, 2012 | LG LMV1630ST Microwave Oven
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Aug 29, 2011 | Magic Chef MCO160UB Microwave Oven
Microwave doesnot heat anything
6 years is a good run for a microwave to keep working
as it is basically a high frequency radio transmitter, take it in for a proper diagnosis and a quote
mostly after 6 years there may be a shortage of parts available for repair so keep in mind that it may be cheaper to junk it and get a later model
Mar 08, 2017 | LG Galaxy Countertop Microwave Oven
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
The light bulbs on the above stove inverter
The actual wattage of the bulb cannot really change anything, perhaps from 10 watts to 30 watts, may, but NOT 25 watts to 30 watts, There simply isn't enough anything to detect if resistance based... I suspect your dimmer is faulty...
Mar 01, 2010 | Electronics - Others
My LG over the range microwave doesn't heat any more
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
That said, you can get free estimates on the cost of a repair but you should also consider a replacement which may be a better option for you.
What they do not tell you about over the stove microwaves is that they are constantly deteriorating due to the steam, oil, and other cooking fumes from the stove below. As a result, their life expectancy is definitely diminished.
Aug 19, 2009 | Microwave Ovens
Kitchen Ranges Logo
985 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
