JBL Powerbass PB12 When left on, will make very loud sound
JBL Powerbass PB12 When left on, will suddenly make a very loud ''pop''.There is a hum while running also. It does work, but makes these largepoping sounds on a regular basis. 6 to 8 yr old equipment. Can this befixed? (without spending more than it is worth) This is a powered12'' downfiring subwoofer in a home audio system. Tom
    Novelist:
  • 133 Answers
Before you spend a lot of money, try checking for these:
- poorly soldered or partially desoldered wires, connectors (power, signal input) or ANY other components (especially the ones that tend to heat up, like power transistors or voltage regulators - a component which has been heating up will cause the curcuit board around it to become somewhat darker)
- dirty or oxydized contacts on ANY of the connectors or switches
- partially or fully blown electrolytic capacitors (see if any are damaged, bulged or blown at the top, these surely need to be replaced)
- internally damaged tantalum electrolytic capacitors (probably there will be no apparent damage to these, but they may cause intermittent disturbances if they are bad).
It may as well be something else, but if your equipment was being used extensively during these 6-8 years, it is likely that some capacitors may have dried up or otherwise failed.
It is also likely that the sound vibrations caused loose connections or bad solder contacts on the circuit board since it is a powered sub with an integrated amp (many audio devices get to suffer from bad solder contacts just by heating up with years of use and even without being exposed to powerful sound vibrations).
I hope you can get it to work well again.
regards
3rq8 (Triarcuate)
Posted on Sep 07, 2009
Testimonial: "Thanks! I wish I had your knowledge. I will take a close look,check everything you mentioned the best I can, and see if I want to repair or replace"
    New Friend:
  • 60 Answers
If you have a pb10 or pb12 and it is not blowing the fuse - then it can be repaired - if it is blowing the fuse and has the ami module then sadly it is a paper weight - please contact us Edwards Electronics - Ebay - We repair amps - sell parts for them etc. and provide technical help. Thanks.
Posted on Jan 02, 2012
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
On/off switch is broken off. on jul PowerBass PB12 anyone have any idea on how i can fix this? everything works fine except if on at certain loudness it will shut off if I'm not holding the switch in...
If you are somewhat technical and can attach wires to the switch - we can list one in our store - contact us Edwards Electronics - Ebay - Thanks.
Oct 20, 2011 | JBL PB12 Subwoofer
I have a JBL PB12 sub, no power - prev wrenching sound on startup
these a internal power control board defective, send to repair
Jan 17, 2010 | JBL PB12 Subwoofer
My JBL PowerBass PB12 makes a continued loud sound when it is on
Have you tried turning the gain down before turning it on. If that works, it might be the internal amp picking up noise somewhere. Maybe even a bad ground. Either way there are only a few things you can try before complaining to the manufacturer or replacing it. Changing its location might help and if it does might indicate RF interference. You can also try running it through a power strip, one equipped with a filter (these are fairly common). Good luck
-Dynami
Mar 29, 2009 | JBL PB12 Subwoofer
Jbl subwoofer
There is actually some good news.  I had this problem with my PB10s (1 have 2 PB10s and 2 PB12s) It is one of 2 things, the first is that it could be a capacitor and resister combination on the amplifier board (which was the fix for our PB10 with the same problem), or 2nd, the AMP IC, which is not available for the PB12. hmmm
Sep 10, 2007 | JBL PSW-D112 Speaker
No sound what so ever
it died and the parts aren't available, same problem here, even took it to an authorized outlet, parts aren't available
Jan 29, 2007 | JBL PB12 Subwoofer
547 people viewed this question
 Grubhead
Grubhead
