Question about HP f2105 21" LCD Monitor
Hp f2105 monitor goes immediately to sleep mode
Just added 4 g's of memory and a new graphics video card to our computer....tested all of this at the store on their monitor. came home re-connneted all wires and plugs and .....low and behold the monitor goes from green light to sleep mode in seconds....cannot do anything with a blank screen....we tried re-plugging everything....pushing any buttons at all and nothing!!!!!!!!!!!!!!!!!! PLEASE...........HELP..................
    President:
  • 2,600 Answers
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
Posted on Sep 07, 2009
Pavilion p7-1148 PC with HP2301 monitor goes to sleep during boot up
hello anon..
why not test the monitor on another PC to prove which box is bad
the mon or Pc.
simple no?
NO OS stated. be nice to know which of 20 OS it is. Windows something is my wild guess. but there are so many, now.
the monitor will always tell you no sig ,
one PC first. this gets the VGA chip alive first. with all sigs
then turn on the Monitor ,if those sigs are missing the monitor always tells you they are, and will not lie to you.
that monitor is newer. not relic, and new monitors never do self sleep like in year 2002. there is no internal sleep on your monitor
it only sleeps on DEMAND, from PC VGA card (lets to VGA ok>?)
simple is easier to troubleshoot.
the 2 sync lines do the sleep mode per VESA spec.
I bet the monitor tests prefectly on any other PC.
I bet.
so lets go from that fact, and work the PC end. make sense?
ok so the VGA chip is BAD.
right, but what can make it bad even when not BAD really.
answer lots, but wait , ive no idea at all what you have.
p7-1148 PC is a desktop
and many desktops , vast, have 2 video chips
one on the MOBO and one in the PCI slot.
i cant see your Desktop rear so must go wild guessing now.
the first thing i do with any older PC is clean all that lint out.
after all if the VGA chip overheats or CPU they shut down.
all do. every one. made does that overheated.
HP has full support page on this nice PC. Decktops are my joy.
im reading your product spec, now. online at hp
it tells me this PC comes with many options video cards etc.
so Ill not guess now. that. (I open the case and look is what I do)
it has option HDMI card there, ? does yours?>
here is your graphic page
Integrated video is not available if a graphics card is installed.
  • Radeon HD 6370D, 6410D, 6530D or 6550D Graphics (model dependent based on processor)
  • Supports PCI Express x16 graphics cards
  • Two DVI-D ports (Both ports can be used at the same time)
the above means, that you are using ON BOARD VGA or
the VGA Card.
which is it , the one you use is failing.
if a card remove it and use the OTHER VGA JACK (onboard)
test that.
so open the case per online manual.
see 2 fans, make them clean,
make heat sinks lint free.
now that it has Fresh air we see if the PSU works.
if the PSU is ok,
diagnosis is serial process, i check the coin cell on each i touch.
after lint removed. 2.9vdc min, new is 3.3vdc.
then i gander at that PCI video card, is the aux power jack fell off?
black yellow wire set, if present , all fast cards have that.
then the video card GPU chip see that, see if the heat sink on it is clean? and i fitted with a fan does said fan work?
like that.
beyond that , is more test, ill stop here, most here fear opening case.
see upgrading guide here, for access to pc,
https://support.hp.com/us-en/product/hp-pavilion-p7-1100-desktop-pc-series/5146449/model/5163175/manuals
Sep 07, 2017 | HP Computers & Internet
HP f2105 Monitor In OSD Lockout Won't come out of Sleep mode
try press f4 or shift f4 on your keyboard or Alt+cntrl
hope it helps
Nov 01, 2011 | HP f2105 21" LCD Monitor
HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further
Apr 03, 2010 | HP f2105 21" LCD Monitor
Power on them monitor goes to sleep
That's normal with some monitors when they do not detect a signal from the video card.
Make sure the cable is firmly plugged in.
Jan 20, 2010 | HP f2105 21" LCD Monitor
I have a HP monitor model f2105, screen is black
Have you recently installed a new video card? If not then you need to because the one you have is broke. If you can plug in another screen to see if that works and if it does then you should re-install the software (if any) that came with the new screen. If you need anything else please let me know.
Mar 22, 2009 | AOC LM729 17" LCD Monitor
My hp w2207h goes to sleep
Turn off the "powersaver" feature on your monitor by pressing <menu> then <management>then <powersaver> select off.
Nov 20, 2008 | HP f2105 21" LCD Monitor
Added a new video card, now my monitor stays in sleep mode
If the computer originally had integrated video, have you tried reconnecting the monitor to that output? Most system boards will automatically detect when you install a separate video card, but on some you need to disable the built-in video in the BIOS before the new card will work. Also, have you considered the chance you just got a lemon of a new card? It happens sometimes (it's happened to me!).
Nov 18, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Hp computer monitor
Hey, the problem you are getting is caused by the pc, when you switch on the pc it sends a signal from the graphics card to the monitor to come off sleep mode and display a picture,
it could be the graphics card, or memory or something more serious,
would try taking out the graphics card and memory and putting them back in see if the machine starts up.. works most of the time..
All the best
John
Jul 26, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Sleeping Monitor
check your video card remove from the system then clean up the gold tip second remove the memory then clean up the gold tip then put it back to the board then restart your CPU
Apr 16, 2008 | HP f2105 21" LCD Monitor
HP f2105 21" LCD Monitor Logo
931 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
