Where is the 8-Digit PIN from the router label on a D-Link DSL-2740B? I've looked all over the device, and through the papers in the box, but nothing?
  • meszanto Sep 07, 2009
    sadly, I have looked under the router, there is no 8-digit number anywhere on the entire device...
  • 224 Answers
This 8-digit number is displayed on a label attached to the bottom of the router, but might also be determined using simple brute-force.
Posted on Sep 07, 2009
I had the exact problem.
First login to 192.168.1.1. If you can't you will have to reset factory settings.
(username/password: admin, admin). Then, go to the top of the screen to ADVANCED. Now, on the far left of the screen you will see a grey list. Go to Wi-Fi Protected Setup.
Posted on Dec 11, 2011
Router 8 digit pin number
Should be on label posted on bottom of device..
Sep 02, 2014 | D-Link DSL Computers & Internet
Hi, I got a tp-link 8901g, but no pin code exists behind the router. Only there is a P/N on its pocket with 10 digits, while I need a 8-digit pin for configure my wireless network. What should I...
If you are configuring your wireless network for the first time there should be no pin required, if there is it should be listed in the manual of the device. If you received this router second hand then you will most likely need to perform a factory reset on it to remove any passwords the previous owner may have set. The default login to the router to access all of the router configuration is user: admin password: admin. To factory reset the router you need to hold the reset button with a pin/paper clip while powering the device on and continue holding it for 15 seconds after powering it back on. This should wipe out all configuration and let you back to stock parameters where you can access the router at 192.168.1.1 and use admin/admin to access and reconfigure your wireless settings from scratch.
Oct 13, 2013 | Computers & Internet
Internet light on modem is solid red
How about the DSL light?
If its solid green then your problem could be a mistyped ISP username/password in the router, or your subscription expired.
Jan 09, 2013 | D-Link Computers & Internet
Problem with modem router DSL-2740B
1.Reset-
The factory reset button is located in the back panel of therouter, and requires a thin, sharp and robust object (like anunfolded paperclip) to be pushed in.
To factory reset, power up the device and wait for 1min. Pressand hold the reset button until the STATUS LED turns off. Releasebutton and wait 1min.
2.Update the firmware-download the required files from the D-Link Support page
3.Contactct your ISP
Jun 13, 2012 | D-Link Wireless-n Adsl2 4-port Modem...
My D-Link DSL-2740B modem Router is already installed and working for all the computers but trying to hook up the Vista OS computer and wireless access is asking for to enter 8 digit PIN. I can not find 8...
Well the PIN number is Usually on the router itself on the back side and its a 8 digit number if that works well and good. Open an Internet Explorer browser page on your wired computer(desktop).In the address bar type - http://192.168.1.1 and press Enter... Leave Username blank & in Password use admin in lower case...8 Dec 2011
Need PIN number! - Networking, Internet, Wireless Forum ...
en.community.dell.com/support-forums/network-internet-wireless/f/3324/.../19426225..or go to this link and see if it helps you find were it is..... Link DSL 2740B modem Router pin number Google Search
Oct 23, 2017 | Computers & Internet
Dsl-2740b router connections freezes
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Oct 10, 2010 | D-Link Computers & Internet
Setup of d link dsl-2740b on my computer
the dsl connection is your broadband signal. check the router box. if the dsl light is off or flashing on the front, the setup will not work. this light needs to be solid. remove all devices from telephone sockets in your house, connect just one filter and your new router to it. check the dsl signal, if the light is solid green. the problem is with the physical setup in your house. If the dsl light still flashes contact your isp or broadband supplier.
Apr 15, 2010 | Computers & Internet
PPP Password doesn't match error
1. You should better check the power supply if it is plug on, properly on a 220AC Voltage. 2. After installing your disk suppose to be you should reset the configuration of your DSL 2740B so that it will restore back to the main configuration of the system. (to reset your DSL 2740B try to look for a small button on it. then press according to standards then your done. Good luck and i hope this steps will help you accurately. God Bless.
Apr 07, 2010 | Zoom X6 Adsl Wireless Gateway Rohs Router
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
9,368 people viewed this question
David Payne
David Payne
