Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Cleaned the brush bar but still not spinning DC14 Dyson
Brush bar had hair and debris and was not spinning. cleared the brush bar and the belt is still in place but not spinning. DC14 model
    Problem Solver:
  • 12 Answers
The belt is broke.
Posted on Sep 07, 2009
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
DC14 doesn't have a conventional replaceable belt. Instead it has a clutch mechanism which allows you to turn the brush bar on to clean carpet, and off to protect hard floors and delicate rugs. It's important to note that the brush bar will never rotate when the vacuum is standing upright, or if you have the brush control set to the Hard floor position.
cleaned the brush bar but still not spinning DC14  - cleaned-brush-bar-but-still-not-spinning-v4hrfkyvukxnfsgo4apodzne-3-0.jpg
If you're confident that the brush bar isn't rotating with the brush control control set correctly, and the vacuum reclined into the normal vacuuming position, I'd encourage you to get in touch correctly. Our experts will be happy to take you through some simple troubleshooting checks - and if a repair or replacement part is needed, they'll be able to provide further details about this.
When you have your DC14 easily to hand, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Jan 12, 2015
    Master:
  • Dyson Master
  • 717 Answers
Hi!, It's Jim with Crucial Vacuum.
It's more than likely that your belt is in need of replacing. Even though it appears attached it may be stretched out and lacking in tension. This would cause the brush roll itself to lack in rotation and suction. On average and depending on usage you will want to replace your vacuums belt once every 3 months.
Remove your vacuums cover, this can usually be done with a screwdriver or coin, and tends to be two to three screws depending on your model. Now you can get a better look at both your brush roll and belt.
If you're looking for replacement parts for your Dyson we carry a large variety of them. Check us out at Crucial Vacuum we offer free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Dyson+DC14&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
    Problem Solver:
  • 9 Answers
The belt has broken, they can be tricky to change, first remove beater bar cover, remove broken belt, obtain replacement not expensive. slide the belt over the motor spindle located in the slot bit fiddly to do, when done place a screw driver through the belt as it will be under a fair bit of tension then slide the beater bar/brush through the belt loop, then reassemble revers of strip down.
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Dyson DC 14 Animal - The carpet brush does not turn. I cleaned thoroughly per the instructions but the brush does not turn. I tried moving the carpet/bare floors switch with the same results - carpet...
    The brush will only spin when the machine is reclined. Not when the machine is stood upright.
    If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
    Jan 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    My Dyson DC 14 is making the horrible "ratcheting"sound only when the brush is engaged on the carpet setting. I have cleaned the brush, so there are no obstructions, the canister is empty and...
    Something is causing the brush to slow down, either it is full of hair or debris or the brush itself is wearing out and may need changed. The noise you are hearing is the motor protector keeping it from burning up becuse there is some type of drag on the brush. If there is no issues with the brush then I would suspect the clutch assembly is worn and needs replaced. Here is a diagram for you to look at and go from there.
    http://www.espares.co.uk/diagram/dyson/dc14-vroom/p/1086/716/0/474352
    Nov 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
    My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
    HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
    It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
    Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
    The brushbar is not spinning.
    Even though the belts are intact they can still be stretched and will not turn the brush. Here is a link to the belts you need:
    Dyson DC14 Replacement Belts
    Nov 24, 2009 | Dyson DC14 All floors Bagless Upright...
    Putting the turbo head brushes back on to a dyson dc14 vaccum cle
    Congratulations on owning a great vacuum cleaner, it's just like mine! Here's what I do: Grab the drive belt and pull while you wiggle the brush bar into it. You have to get a little bit physical with it. The ends of the brush bar will nestle into their keeper pockets nicely when you've got it right. Good luck!
    Sep 20, 2009 | Vacuums
    When I tilt back handel and turn dial to carpet It makes a loud grinding noise
    On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
    Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson vacuum cleaner-brush bar is frozen
    Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
    However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
    Apr 05, 2009 | Dyson DC14 All floors Bagless Upright...
    My dyson dc14 not sucking only from the hose
    Hi- I have the same problem: suction fine, but the brushbar was not spinning. I went 1st to the Dyson site and went thru their troubleshooting guide and I'd done all those things, so I called Dyson (1-866-MY DYSON in the USA) and they walked me thru a very simple solution.
    What worked was to "rest" the bare floor/carpet adjustment, and it's very easy! You do this by clicking the carpet to bare floor adjustment back and forth at least 5 times. Make sure when you end it's on carpet. Then tilt it back all the way from the upright position so it's flat on the floor and turn it onto it's left side. The carpet indicator should be below the word carpet. THAT WAS IT! As soon as I turned it on again, the brush bar is spinning great! I wish I could tell you right now how well it picks up, but unfortunately I took out the filter and rinsed it, so I have to wait until tomorrow to **** anything up. However, I'm sure it will work now that the brush bar is moving. Like I said, the suction was fine.
    Just as an FYI--If you call, they will have you try other things to rule out other problems 1st. I had already done all the things suggested in their troubleshooting guide on their site and the only additional thing they asked me to try was to turn it on and tilt it back as though you are going to vacuum and make sure the suction from the top tube had stopped, as it normally does, and mine did.
    Hope this helps!
    Liz
    Dec 03, 2007 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson DC14 Animal Vacuum - terrible loud noise
    What I found was that it is the roller brush. If you are willing to get a little dirty and do it yourself, there is the roller brush that most likely needs to be cleaned. After a little tinkering of my own, the roller brush can be slipped out or just shift it out of place to clean it. There are two ends to the roller brush and the brush itself. Of you twist the two ends until the come apart you would probably find a lot of hair and other long strand items wrapped around the rod that goes through the brush. Once you clean that out it should work like new. If that does not work then it is probably the clutch which is what the belt around the roller brush is connected to. Hope this helps, it is a simple solution.
    Jul 30, 2007 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
    758 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Nick Olsen
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
