Question about Car Audio & Video
I have a bolt amp and it keeps blowing fuse why?
  • 1,498 Answers
Hi Jeff,
If they're blowing as soon as it powers on, it's likely to be a short.
Pull all signal cables, lower the volume and power it.
If it doesn't blow the fuse, attach the cables one by one starting with the outputs. When it blows, you'll have you suspect. Trace it to it's dest/source to find the problem
Best regards,
Mike
Posted on Sep 07, 2009
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
30 amp starter fuse keeps blowing on 98 cherokee
you may have a short (verify the integrity of the insulation of the positive wire from that fuse going to the rear window defroster, check the relay & switch.) try to replace the relay.
Oct 03, 2015 | Cars & Trucks
1996 dodge ram 1500 keeps blowing 30 amp engine control fuse
Look for a part of that wire cable that is rubbing on metal somewhere or that some mechanic pinched under a bolt or drilled a screw through. It may take some time but the closer you look at that wire from end to end the faster you will find the problem. Blowing a 30 amp fuse means something is shorting out pretty good so go find the short.
If you need further help, reach me via phone at https://www.6ya.com/expert/lloyd_4256582adacd68ee
Oct 19, 2013 | 1996 Dodge Ram 1500 Club Cab
How to change 80 amp fuse on 2008 Chevy Equinox
Locate the fusebox
Locate the 80amp fuse you wish to replace
Remove the old fuse
Take new fuse and insert it into slot
Test the fuse by seeing if the electronic that runs on itsit is working
Oct 13, 2013 | 2008 Chevrolet Equinox
Fuse keeps blowing to my dash guages in my 95 gmc sierra why?
have you recently installed a new radio ? I have knowen people to install radiosincorectly the dim wire behind the radio shows as a earth. however when you turn headlights on this becomes a positive. if you have wired this wire to your sterio this is whyyour dash lights & internal cab light etc keep blowing.. if your wondering why sterio still works is because its earthed through the aerial or mounting bolts.
Jan 05, 2013 | 1995 Chevrolet Silverado 2500
Blowing fuses
It's drawing too much current. make sure you have a nice solid ground to your car chasis( i use seat bolt or something like that) and that your wire is the right gauge. If it's still popping your fuse make sure you are wiring the subs as specified by the manufacturer.
May 10, 2010 | Boss AUDIO SYSTEMS D13002 Car Audio...
2009 e250 keeps blowing 10 amp parking fuse then
if it keeps blowing the fuse you have a short in the wiring
Sep 11, 2009 | 2009 Ford Econoline Cargo
Chevy silverado keeps blowing fuses
Your 20 amp fuse will not blow if glowplug wire shorts. each plug draws 15 amps which is 120 amps total.I think there are in line fuses for them. Try to wring out where each output from the fuse goes, disconnect all and reconnect one at a time till it blows.That should point to your problem process of illumination! Good Luck!!
Aug 25, 2017 | 1994 Chevrolet K1500
97 dodge dakoata main fuse keeps blowing 140 amp fuse
Regulator in alternator obviously faulty, have it bench tested & fixed or replace alternator, and cure your problem.
May 19, 2009 | 1997 Dodge Dakota
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
