Question about Lexmark X2500 All-In-One Printer
My lexmark printer does not turn on i checked everything and nothing
Updated to snow leopard and now I can't print with Lexmark x6570 wireless printer
do you try to restart the printer..do you check cables on it..if you try all..and didn't work..try to contact the hot line of the technical support.
Nov 07, 2011 | Lexmark X6570 InkJet Printer
Ran out of ink, changed the ink and the printer prints a blank paper...checked the ink everything is good...still nothing printing??
Make sure you are inserting genuine Lexmark cartridges.
Try to re-seat the cartridges into the printer. Remove the cartridges > close the printer cover > unplug / re-plug the printer into the power source to reset it > when the printer turns on, firmly reinsert the cartridges. Try to print a document again to verify that the problem is fixed.
If that doesn't help, try to clean the print cartridge nozzles. Open the Lexmark Solution Center on your computer by going to Start menu > Programs / All Programs > Lexmark Z600 Series > Maintenance tab > Under Select a Maintenace tool, select Clean to fix horizontal streaks. > click Print. Then try to print a document again.
Sep 13, 2011 | Lexmark Z615 InkJet Printer
Hello! I turn on the printer with USB data cable atached to my pc and the Ready led is on. I installed the printer driver from lexmark support site everything beeing ok until now. I try to print from my...
Please try to switch to another usb port or try using a different usb cable. try to unplug and replug the cable and check if the computer was able to detect the printer.
For further assistance please contact Lexmark Technical Support
Aug 06, 2011 | Lexmark E321 Laser Printer
What do I do about Error # 1200 for my Lexmark X4270?
1. Press Power to turn off lexmark X4270.2. Unplug your lexmark X4270 from the wall outlet.3 Check for paper jams.
4 Plug in your all-in-one lexmark X4270Cartridge
if everything is ok still the problem persists->The cartridge carrier is jammed.1. Turn off you all-in-one lexmark X42702. Unplug the all-in-one lexmark from wall outlet 2.Open control panel 3.open the cartridge access door 4.Make sure the cartridges are snapped in properly 5.check for objects obstructing the cartridge carrier 6.plug in your all-in-one printer 7.press power to turn on teh printer.
This should fix teh problem.
Sep 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Unlock scanner keeps appearing on my lexmark x85 printer
Go to the Lexmark web site here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
- In the SEARCH BY MODEL box, type in X85 and click SEARCH
- In the SEARCH THE KNOWLEDGBASE box, type in UNLOCK SCANNER. It will show some instructions for the X83, but that was the little brother of the X85, so should work.
Steve
Feb 23, 2009 | Lexmark X5150 All-In-One InkJet Printer
I can no longer print to my Lexmark 6500.
hi.
if u dont have the cd,try the downloaded version from www.lexmark.com ..try connecting usb cable and check if printer works,,,if it does then its an issue with wireless connectivity..
good luck
Jan 25, 2009 | Lexmark Office Equipment & Supplies
Printer installed & ready but wont print
found solution: driver software had an error while installing & only installed half the proper software. i had to uninstall the lexmark 5200 serious software completely & download it again from the lexmark website.
i talked to the lexmark customer service live chat line on their website & found out what the problem was. they are very helpful, i highly recommend using it if you have a problem with your lexmark product!
pretty simple solution, its just a little time consuming.
Nov 22, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
Sep 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer wont turn on
change the power cord and see. bye
Sep 26, 2007 | Lexmark Z640 InkJet Printer
Lexmark X2500 All-In-One Printer Logo
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
