Question about Audiovox fpe 3207 32 in. LCD Television
Audiovox FPE3207 LCD TV. Normally the word 'AUDIOVOX' appears, goes off, and, after a brief time, the TV comes on. Now 'AUDIOVOX' flashes, and after a while, the sound and a faint station image pops on and off as the screen tries to light, This cycle repeats, If I turn the set on and off a number of times, eventually the screen lights fully and the set operates normally. I suspect the inverter but can not find a replacement.
5 Suggested Answers
  • 3 Answers
SOURCE: Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Posted on Oct 21, 2008
SOURCE: Audiovox LCD FPE3206 problems
Hi, All.
I ordered a new power supply module on ebay. Cost about 106.00 delivered. Came in a few days. I replaced the unit, bunch of screws, all wires were cable plugins, no problems at all.
After reassembly, it worked. What can I say? Sometimes ya just get lucky.
tom
budmrtn
  • 11361 Answers
SOURCE: Audiovox fpe2705 inverter board replacement
You need to verify first that you do have 24vdc feeding the inverter boards, if you do have 24vdc then we can be sure it is the inverter boards. The inverter board will have very small surface mounted fuses, check for that also.
Posted on Dec 02, 2009
SD Tech
  • 14553 Answers
SOURCE: the tv will not come on. it started to have trouble coming on, and them it quit all together. while it was starting to act up, when it would not come on it would reset the clock on this audiovox KLV3
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on here is what my guess would be.
Every set has a standby power supply that is running 7/24 if the set is plugged in and it supplies voltage to the remote circuit that turn on the main power supply for the tv and hence turn the set on.
This is an area where companies cut corners by using lower rated voltage caps. By this I mean Standby usually provides under 10 volts to trigger the set on----what they do is use filter caps rated at say 10 volts max in a circuit with 9 volts (example)=with the standby on all the time the filter caps (electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times and gradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of the capacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of them happen when set is a year or two old (no warranty) and all you have to do is look at the top to locate bad ones.
They are generally black or blue and round and vary in --they have two connections each--a + for positive and a - for negative--not unlike a battery which in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silver and metal looking with creases on top and if bad they will be puffed up on top---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10 vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with the same value capacitance (like the 220 uf) but go up to at least in this case (from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger so sometimes there is an issue of physical space for the replacement on the board to fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make 25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it may be the problem you have.
See attached photo of a typical cap and if you have questions or need advice let me know. 8_30_2012_2_40_15_pm.jpg
Posted on Aug 30, 2012
Audiovox KLV3913 TV/DVD dead
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 06, 2017 | Audiovox KLV3913 12 in. LCD TV/DVD Combo
AUDIOVOX fpe3707hr power lights up blue screen but no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 07, 2017 | Audiovox Televison & Video
My 32inch audiovox flatscrren will not come on but
Now in the front of the tv panel power blue light on and it solid green?Take ur tv aparts.The T-con board, this board sit in the botom in the middle of the LCD screen.This board is defective replaced it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-con board for the replacement.
May 11, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
Audiovox FPE3000 will not allow Comcast remote operation
Try to find out who really makes Audiovox alot of time a big company like maybe sony or rca or such may make a tv like that and try there codes as well
Mar 28, 2010 | Audiovox FPE3000 30 in. HD-Ready LCD...
Tv power comes on but no picture th name Audiovox
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 01, 2009 | Audiovox FPE3206 32 in. LCD Television
I TURN MY TV ON IT SAYS audiovox for 30 sec. then CUTS OUT
one of two things puffy caps in your power
supply , or your inverter is failing cap are easy fix , but inverter not try shop jimmy .com
Sep 19, 2009 | Audiovox FPE2306 23 in. LCD Television
How can I unlock it (Audiovox tv)?
you need to search your universal remote code for a audiovox code try all of the audiovox codes then once you find the right one, how you will tell is when you turn the tv off and on click menu then unlock the tv
Aug 08, 2009 | Audiovox Televison & Video
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
Fpe2706
my LCD 1081 TV won't turn on only red light flashes all the time, and it is a brand new one only 3 days ago i bought it
Mar 12, 2008 | Audiovox FPE2706 27 in. LCD Television
Audiovox fpe 3207 32 in. LCD Television Logo
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
