Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Jenn-Air bottom freezer ice maker not working
Jenn_Air Model #JCB 2059 GES bottom freezer refrigerator ice maker stopped working. The arm is in the slot. I checked it using a mirror.
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Posted on Sep 07, 2009
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Jcb 2059 Jen air fridge not cooling freezer o.k.
Its a defrost issue.The freezer works,then cooling starts and then its time to defrost.But in defrost the unit is not working.It can be faulty defrost assembly parts.Or the problem is with defrost timer at the lower back side of refrigerator.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Jcb 2059 ges Jen air fridge part not cooling freezer o.k.
If freezer cooling but fridge not cooling,then its a defrost issue.First freezer cools,then cool air from freezer gets to fridge and fridge gets cool.But if freezer defrost cycle not taking place then its faulty defrost assembly parts.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Jenn-Air JCB2059G Bottom Freezer...
My freezer has ice on the bottom,we keep cleaning it out and the ice keeps coming back
I need to ask, what kind of ice are we talking about, ice cubes or a slate? If cubes there is a gage that can be added to the ice maker arm to prevent this. If its a slab or slate, than I would look at the defrost drain system in the back of the freezer to be clogged. If no ice there, is it possible not all the water from the ice maker is getting into the ice maker?
I hope this helps or leads you in the correct direction.
Aug 17, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
We have a Jenn-Air Refrigerator/Freezer (Model #JRSD226) and the ice maker has stopped working.
Check for blockage in the water line in the freezer. If so, defrost it. Might need a new water valve. Maybe a bad ice maker too.
Another possibility is that it's not cold enough in the freezer. Should be below +10F.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 25, 2011 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Excessive and annoying noise right from the start
its possible, one way to tell is simply lift the arm on the ice maker to the off position, if it s off it will stop rotating and you can rule that out as the reason, if indeed that is the case you can replace the entire ice maker assy, its only held on by 3 screws and a wire harness. easy repair if needed
Nov 09, 2008 | Jenn-Air JBL2086HES Bottom Freezer...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
630 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
