Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
SN ?Non Functional High Temp Sensor? error message
I got this error after the spa was unplugged for a month. Drained then cleaned.
    Champion:
  • 246 Answers
Unplug and plug after 20 sec. turn pump fast and wait for 1 min if nothing air is trap anf need to be out
Posted on Sep 13, 2009
I am getting a sn 21 error
non functioning high temp
Apr 29, 2014 | Jandy Pool & Spa
I have a Dream Maker X400 hot tub that wasn't used for a year or so, I replaced all of the jet heads and filled it - when I started it the light starting flashing on and off with a clicking sound coming...
Hello, and thanks for the question. Your error code is actually "SN" not "5N" but they are sometimes difficult to discern on the LCD topside display. The SN error code is for a Non-functional High temperature sensor which automatically kicks the heater off and trips the breaker. You can purchase new sensors for $75-$85 (it could be more, my pricing index is quite a few years out of date) I'm not sure where the sensor is located in that particular tub, although it is most likely in the heating canister. Make sure the power is off at the breaker before attempting any tub repair. if you have shut-off valves to the heating canister you may not have to drain the tub, remove the heating can and replace the sensor you will have to plug/unplug the sensors from the power pack/circuit board. I hope this helps =)
Oct 27, 2013 | Pool & Spa
Fault code 5n1
I'm assuming this is a Cal Spa? I'm going to reply to this but I'm willing to bet this issue resolved itself?
Error code of Sn1 ("Sensor 1"- Spa is shut down. High-limit sensor is not working.)
This could be a temporary condition. If not, your high limit sensor is bad. "SN" means your spa has a sensor error and "1" means it's the high limit sensor. Without knowing the year of your spa I don't know which manual to give you but the link below has just about every Cal Spa manual available.
http://www.calspas.com/manuals/
Apr 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
Overheat errors
possible temp sensor bad if ok bad control board
Feb 25, 2013 | Balboa Instruments BALBOA VS500Z PUMP ,...
We are getting the error message of NON FUNCTIONAL HIGH TEMP SENSOR. Does anyone know how to fix this on the Dream Maker Spa B6L series?
Not much to go on but try opening the drain valve for a few seconds. If you have an air lock this give you a high temp code. When you open the drain it will break the air lock and start it pumping again.
Nov 27, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
THE ERROR CODE READS SN. (NON FUNCTIONAL HIGH TEMP SENSOR) THE TEMP SENSOR HAS BEEN CHANGED. STILL READS SN. I HAVE TRIED UNPLUGGING AND REPLUGGING. BUT NO RESPONSE. WHAT ELSE COULD I TRY?
Did you replace both temp sensors or just one? Did you make sure that the new sensors are the same model? If you did replace both sensors with the correct ones, the main board is bad and will have to be repaired or replaced. The actual manufacturer of your controller can provide limited technical support for someone who has the ability to use a multi-meter and test a few components at the spa over the phone.
Sep 07, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
We have a Great Lakes spa with a Balboa control panel, manufactured in 1992. When you plug the spa in, it will shut down and read Sn on the topside control panel. We have replaced the high limit/temp...
Contact Balboa's Customer support department directly at 800-645-3201, follow the prompts to customer tech support (or press 0 and ask for customer support). You will need to be at the spa, control panel open and ready to read off the chip number, and you will need to be proficient with a test meter (AC voltage). The SN error is related to a bad sensor(s), but can also indicate a failed board. An incorrect sensor set will also create this problem, so confirm you used the exact or compatible replacement. If the SN code issue is no longer a problem, but the spa is still not heating, look and see if the heater led is on. If it is, you likely have some burned relays on the board, which can be replaced cheaper than replacing the board. If you need more help, email me at info@coastsideservices.com
Jun 12, 2010 | Pool & Spa
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
No heat sensor
you need a new high limit sensor for your control box. What is the model number of the control box?
Jan 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
1,231 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
