Question about Garden
Operating instructions vigoro gear drive sprinkler on 4 ft tripod - have no clue how to use it.
Orbit sprinkler manuals
Check for obstructions in the mechanism. Follow the instructions on the adjustments.
Aug 09, 2014 | Orbit Irrigation 58308 Tripod with Brass...
Is there a manual for the orbit h2o-6 gear drive sprinkler on tripod?
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 24, 2014 | Orbit 58565N H2O-6 Gear Drive Sprinkler
Is there a video on programming a toro lawn master II timer
I have found these timers to be the most difficult for a homeowner to master. I suggest going to Toro's web site and downloading the operating instructions.
Sep 30, 2013 | Toro 53805 Lawn Master II 4-Zone Landscape...
I need instructions to the Vigoro- Duo Deluxe water timer 9 volt battery operated # on back is 0708..# on fromt top left is 225-379 Purchased at Home Depot I has5 to 6 cycles that can be programmed. I...
The vigoro duo delux might be same as Melnor 3100
Open following links:
http://www.melnor.com/instructions.php
http://www.melnor.com/instructions/3100_InstructionSheet.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Hardware & Accessories
I just purchased a Vigoro zinc spike sprinkler . I want to set it to 360 degrees watering . The only instruction to do this is : Full circle : Left trip pin I've played with it a bit but have not hooked...
Lift completely up or down on the mechanism that allows for it to STOP against the setting pins. 360 is a full circle and if you can't spin the head all the way around, readjust the mechanism until it clears both the right and left stopping pins. Once you accomplish this and turn it on, you will have 2 options for operation...progressive traveling and return traveling. The trip lever can be moved to set that accordingly.
Apr 19, 2011 | Garden
I have 2 Vigoro 196-036 watering timers. Why does water come out of the three holes near the battery compartment on one of them?
It comes out of the holes because the water goes in the holes. That might sound dumb but Vigoro designed these only to be in dry conditions, such as attached to the water line. I used them for sprinklers, but the water poured into the timer so bad it shorted it out in a week. I did find a vigoro timer with no holes and a sealed unit, and they work great. But I can't find them anymore.
Aug 25, 2010 | Hardware & Accessories
Can i get online instructions on how to program my
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
Jul 22, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
Regarding the Vigoro Electronic Water Timer, Model 196 036: How do I program the timer to water every day, in the early a.m., then in the evening? Is the greatest hourly spread per day 12 hrs.? In...
I think you almost have it right, you can program how many hours apart.
4=6 x per day
6=4 x per day
8=3 x per day
12= 2 x per day
24=1 x per day
Then you set how long you want it to be on, but that can't exceed your hour setting. I believe these are the same timers as Melnor. You can go to their web site for manuals. http://www.melnor.com/instructions.php. If you really want exact timing, I'd get a quality electric timer, and then buy a electric valve such as you'd use for a sprinkler system.
Jul 13, 2010 | Garden
Garden Logo
647 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
