Question about Hotpoint Dryers
How to change a dryer belt . Model number DLB1550BDLAD. What is the most effective way to put on a new belt. Any advice or tips?
  • 304 Answers
Unplug unit . Check to be sure you have 240 Volts at wall outlet.
Open the door and look along the front upper edge of the dryer along the front edge. There will be 4 screws going into the top. Remove them and lift the top.
Near the floor at the front of the dryer about 1 inch in and 4 inches off the floor there will be a 5/16" hex head screw on each side that is black like the toekick. Loosen each about 3 turns but do not remove them. Leaning against the front of the dryer, Look down inside the open top dryer from above on each left and right edge there will be a 5/16" hex head screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward toy about 3 inches at the top and then lifted off the lower screws and swung away to the right from the case. Be careful not to strain any wires connected between the case and the front. Place the belt around the drum with the ribs of the belt facing the drum and hang the remainder of the belt into the lower part of the dryer.
Reverse the process of the above three paragraphs to reassemble what you have done.
Pull the dryer out enough to get behind it. there is a lower black panel to be removed by taking out all the 5/16" screws around the edge. Swing the panel aside and look into it. You will see the motor to the right and the loose part of the belt hanging somewhere in the middle.
Place the belt around the motor and idler pulley so that the ribbed side of the belt goes in the grooves on the motor pulley and the flat side runs around the idler pulley, according to the GE chart on this image.
http://www.applianceaid.com/images/belt-config.JPG
Turn the drum by hand a few times so that the belt aligns with the pulleys and is not twisted at any point.. Reinstall the rear panel again and you are finished.
Good Luck
Posted on Sep 07, 2009
  • Hotpoint Master
  • 8,220 Answers
Trying to replace belt around drum. reached in under drum to put belt around both pulleys but the belt is not tight. any suggestions?
You need to ensure you have the belt properly routed (ribbed side facing the drum) around the motor pulley and the tensioner pulley.
Since you posted no BRAND NAME or MODEL NUMBER, the only advice I can provide you with is to go to repairclinic.com and select "Get Repair Help". Under the Repair Help section, select "Dryer". Under Dryers, there is a link for dryer belt diagrams. There is an extensive list of diagrams to choose from based on manufacturer. If you do not find what you are looking for there, or if you have further questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Oct 28, 2010 | Dryers
My dryer wont heat or dry the clothes,I would like to know where the heating element is and how to change it? model-DLB1550BDLAD
first check the thermostat coupler on top of the inner door,,if this has packed up none of the two heaters will work? the heaters are in the frount behind the door
Aug 04, 2010 | Dryers
Hotpoint dryer model DLB1550BDLAD. How old is
get the serial number and go to www.hotpoint com.and yes they are still a company.adrian,,,,
Jul 12, 2010 | Hotpoint Dryers
Need to replace the dryer belt and have the dryer taken apart, how do i put the belt back on?
Thre are a couple of different ways, the dryer belt goes back on a Whirlpool manufactured dryer (including Kenmore). However, since you posted no MODEL NUMBER, I can only give the following advice:
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to diagram H or K.
If you aren't sure which configuration to use, please post back with your model number, so I can provide you with a more difinitive answer. I hope this helps you.
Jan 21, 2010 | Dryers
HOTPOINT DRYER, MODEL DLB1550BDLAD. BELT INSTALLATION.
hotpoint model # DLB2650BDLWH
How do you put a new belt on?
Feb 08, 2009 | Hotpoint NVL333EY Electric Dryer
Need to know what size belt goes on whirlpool hotpoint dryer model#DLB155OBDLAD
Your model number is actually "DLB1550BDLAD". The character after the second 5 is a zero, not the letter O. I'm only pointing this out to you because it is often hard to read these characters and it will avoid confusion for you in the future. The part number you need for a belt replacement is "WE12X82". You can find it at searspartsdirect.com under the "Blower and Drive Assembly" heading. It is listed as item number 213. The illustrations aren't the greatest, but they may help you as well. If you do not wish to order on line, take the part number provided and go to your nearest appliance parts retailer. They should carry a stock of different dryer belts. I hope you find this information helpful. Let me know if you have further questions.
Oct 07, 2008 | Dryers
Kenmore dryer model 86274800
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. However, I will give you a link
to a brand and model page where you will have to input the complete model number to get the proper diagram.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0079.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 25, 2008 | Dryers
How do I install a new dryer belt and can I get pictures
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This link will go to a page where you have to click on the brand and year model of your dryer to get
an image of the diagram.
Thank you,
Dave E. (Illeagle)
Jun 25, 2008 | Frigidaire Dryers
Model lgn20000kq1
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Thank you,
Dave E. (Illeagle)
Jun 10, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
130 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
