Question about Frigidaire HV2730B Kitchen Hood
Problem: Won't stay on!
My HV2730B-A comes on for about 5 minutes, shuts off and won't come on again. The hood comes up the fan starts and immediately closes down.
  • 833 Answers
Skip, best guess...either the motor is bad or there is a circuit breaker in the unit which is popping. With the power off, open the unit and try to turn the fan by hand. If it turns hard, the motor is shot. If not, find that breaker and get a new one. They do wear out. You'll probably find it in the housing. They are often small boxes with a wire going in and another going out leading to the fan motor.
Posted on Dec 09, 2007
HP M7357c overheating problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 03, 2012 | HP m7357c PC Desktop
Oven won't stay on
I would say a fuse in cuircit board or something in the mother board
Dec 19, 2011 | Bertazzoni X30 4 GGV X Gas Kitchen Range
How can I tell if the engine cooling fan is functioning properly?
The cooling fan is made to come on when the engine reaches a certain temperature. To give a simple and general test - turn the AC on high - it your AC and fan are both working correctly the fan should come on almost immediately. If not within very few minutes like 5 or 8.
Also at operating temperature the fan will run as well. In the early morning before you start the car open the hood - fill the radiator while the engine is still cold. start the engine and wait about 10 minutes or so. The fan should come on before the engine over heats. This may take up to 20 minutes and the fan is designed to run after the car is shut off IF - the temperature is hot enough.
Aug 12, 2011 | 2005 Chevrolet Aveo
WINDOW XP WOM'T SHUT DOWN
Hold the power button in for a few seconds it will shut down. Then unplug system and push the power button down with it unplugged then replug it in and power up again. Then do a proper shut down again to see if the problem fixed. I hope this assisted you. John
Feb 07, 2011 | Microsoft Windows XP Professional
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Frigidaire HV2730B Kitchen Hood Logo
147 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
