Question about Garden
Riding mower wont start
A freind gave me a riding mower with a briggs motor, i found out no spark to the spark plug, where does the fire come from and how would i test farther to find the problem its a dynmark mower
  • lucky99star May 11, 2010
    need more info model serial and type codes from engine you will find these on the engine usually located around the exhaust but it depends on the engine
  • 1,498 Answers
Hi Pry
The spark comes from the Magneto. Follow the spark plug wire and you will find the magneto at the end of it
The first thing you should check though, is the safety kill switch. There is a pressure switch in the seat that kills the engine in the event the driver falls off.
You need to be sitting on the mower to start it.
If the switch is ok and you still get no fire, it's the magneto.
Best regards,
Mike
Posted on Sep 07, 2009
Engine wont fire....
There should be 1 black wire that grounds the coil(s) for kill. Be sure this black wire is not grounded when switch is in on or start position. It will be connected to the coil(s) at the flywheel.
Feb 10, 2013 | Snapper 21 hp* Briggs & Stratton...
Yard Machines 13.5 HP riding mower wont start. It turns over fast, has good spark, good gas, good filter, clean carb, just wont fire. It ran fine yesterday and i parked it last night and tried to fire it...
Hi, check that the choke is operating and make sure the plug is wet after cranking. If so replace the sparkplug as it may be breaking down under compression. Also make sure it has compression ad it may have a stuck valve. regards Phil
Jun 19, 2012 | Yard Machines 155 Torque Briggs Stratton...
We have a murray riding lawn mower 287707 it turns over and it wont start. Spark plug new and it sparks and just changed oil, cleaned carbuator, new fuel line and new air filter we tried everything. Can...
on the bottom of the carb there is a solenoid if that solenoid doesn't have power it shuts it off a bad safety switch will cause it to not have power if so start with the clutch/brake switch
Jun 03, 2012 | Briggs & Stratton Garden
Riding mower with 26hp briggs and stratton motor runs about 20 to 30 minutes thens cuts out
It sounds electrical in nature check the solenoid for continuity, check your key switch it may be bad also, check the spark plug wires and the part they hook into. Look for melted wires and replace as needed.
May 11, 2012 | Husqvarna Garden
My scag mower won't run and spark plugs are not firing
unplug the harness and crank it over see if there is spark then is yes check the safety switches if not check the coils
Apr 12, 2012 | Briggs & Stratton Garden
I have a briggs and strattan 18 horsepower engine on my craftsman mower and it wont start, i replaced the starter and it still wont start! It wont even turn over, in fact it binds the starter, but if I...
Have the battery tested at an auto parts store to ensure there is enough power in it. Sounds like it's strong enough to turn the motor with no compression (spark plug removed) but too weak to turn the motor with compression. Also check for loose or corroded wires.
Sep 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
2.5 year old, 15.5 hp Briggs cranks but wont fire
make shore that the valves are not rideing no tappet clearance back both roccers of and try for comp there has to be a tappet clearance for there to be comp or set the inlet at 5 thou and the exhaust at 10 thou on the comp stroke .horizontal b/s have a very good past very good engine in the past
Jul 13, 2009 | Briggs & Stratton 66set Panzer Tractor...
Briggs and Stratton 28N700 series 15 hp mower motor
do you have spark at the plug - remove it and ground it while you crank the engine . is this an overhead valve engine ? have you checked compression .
Oct 24, 2008 | Garden
Garden Logo
178 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
