Question about Whirlpool Washing Machines
Washer made a loud noise after it filled up
My washer filled up completely with water and when it was time to start washing instead it made a very loud noise.
  • 555 Answers
The washer machine tried to spin but the bearings (or other mechanical part) broke. This is a serious issue that needs a technician for repairs.
Posted on Sep 07, 2009
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Machine Starts filling then spins 3 turns and a loud noise and stops?
Hey friend, I appreciate your post!
From my understanding you Frigidaire washer will fill with water, spin three times, make a loud noise, and then stop. You could possibly be seeing an issue with your control panel or motor. I would recommend having a technician come out to the home to properly diagnose and repair your washer. I hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
I have a Maytag A183 top loading washing machine. It recently starting making a loud buzzing noise when you first pull out the knob to start it. If you turn it off and on a couple of times, the sounds...
That loud buzzing noise is your water fill valve. First turn off the water valves to the washer and unscrew the hoses and check that the filters are not corroded or clogged. I had a maytag washer that was doing the same thing and finally the lid switch and timer had to be replaced. I would unplug the washer and remove the screws along the upper rear cover behind the timer assembly and check that all connections are secure. Unplug them then plug back in if neccessary. Then put the cover back on plug back in and try it.
If it still does it you might need the water valve replaced.
Mar 13, 2011 | Washing Machines
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Whirlpool LHW0050PQ - Water wont empty or fill
This sounds like a plumbing problem. Lets see if we can isolate it. Turn the valves off behind the washer and remove them from the washer. Remove the washer drain hose from the stand pipe. Stuff one of the hoses into the now vacant drain line and turn the water on. Then do the other hose. Any noise? Now reconnect the fill hoses to the washer and reinstall the drain hose to its' place. Turn on the water valves at the wall, set the washer to a cold/cold cycle and start it up. Listen for noise. Now shut the machine off and set it for a hot/cold cycle and turn it on. Listen for noise. If you get no noise now, it's all good. If you're getting noise from just your hot water, your water heater is set too high and you have steam propagating in your plumbing. Your washer water valves (where the hoses connect to your machine) will only do this if you have low water pressure coming from the wall. Still, it'll be a plumbing problem.
Jul 28, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De
