Question about Vivitar ViviCam 5100 Digital Camera
Shutter When I press the shutter button and it takes the camera the screen goes black and stays then you hear a click and it will pop back up. Is there a setting I need to change?
  • 797 Answers
Hi:
Try this:
Go to the menu and or setup menu. RESET ALL.
See if the camera works right,
If not, set the menu like you may choose, then test.
If all fails, then there may be a problem with the ccd or sensor.
Go to:
http://vivitar.com/en-us/Support.aspx
Ask for your model.
Posted on Sep 29, 2008
What makes the screen stay black when camera is
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't help...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 14, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
The screen is black, i cannot see anything on the
First thing to check is to make sure that you didn't just accidentally press the DISP or DISPLAY button on the back of your camera, manually turning the screen off. Press the DISP button once with the camera turned on. If that didn't correct the problem, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 10, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
The display will not show anything when the camera is turned on. All the options are on the screen but nothing else. It is black.
First off you didn't say if the pictures it is taking are OK, or if they are also black. If the pictures are turning out fine, then it's likely that you just accidentally pressed the DISP or DISPLAY button on the back of your camera, accidentally turning the screen off to save batteries. Press the button one more time to turn it back on.
But if the pictures take are also black, then a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Apr 04, 2010 | Canon PowerShot A540 Digital Camera
Camera works but the screen went black A640 except for video and color swap. Did I press a button? I was shooting in cold weather.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
But if you've already tried this, have you also tried downloading any of your photos taken with the black screen to your computer? Are the photos also black? If so, you might instead be experieincing a stuck shutter (possibly due to the cold weather).
Jan 03, 2010 | Canon PowerShot A640 Digital Camera
Black screen
Simply right click on the track itself and select send to/DVD-RW or CR-RW depending on the type Compact disc drive you have. Then you will see a notification, "you files to be written to CD." Simply click on it or go to your Compact disc drive on My Computer and click “write these files to CD.” Then follow the screen instructions. IT is that simple. All you need to do is press and release the display button until the screen displays. Usually Canon Powershot cameras have 3 display modes:- colour, black & white, blank. Your camera is set to blank that is why you cannot see any image/screen displays no image. Just press and release the display button until the screen displays. That should do it.
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
Camera turns on but wont let you take pictures screen is dark
When you press the shutter button, does it make the shutter sound?
Also do you see any display?(the aimer thingy.)
Try pressing the red camera button when it goes black, if it works the cameras just in power saver mode.
Aug 08, 2009 | HP Photosmart M517 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
HELP! dropped camera, lens won't go back in, shutter won't close
Tapp the lense GENTLY in the opposite direction of the misalignment
Nov 25, 2007 | Kodak EasyShare DX6490 Digital Camera
Vivitar ViviCam 5100 Digital Camera Logo
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
