Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I got some dots in every pictures i have taken and it's all on the same spot. what are these? is this a pixel problem? can it be fixed?
  • dtom May 11, 2010
    Is it a white spot or dark/black spot?
    Brigadier General:
  • 4,090 Answers
Not quite enough information for solve.
have you printed these pics and seen the spots?
whayt happens if you print it on a different printer.
Are these dots visible on the preview of the camera?
It could be moisture spot ore dirt inside ofthe camera or even the lense itself Sometimes bacteria will grow inside the lense.
Inspect the lens itself, as well as the mirror insie the camera to see if there is dirt or speck on them.
Please rate our help to keep the FREE sevice online ++++ Thank you for using FIXYA
Posted on Sep 07, 2009
I have a Nikon coolpix 5700. Recently have taken a bunch of pictures that ended up having pink spots show up on the pictures. It does not matter what setting the camera is on or how the zoom is set it...
Your CCD sensor most likely has what is referred to as a "dead pixel" or "stuck pixel", which is a pixel in the sensor that is not functioning properly anymore. There is not much to do to get it fixed. If you have an image editing program such as photoshop, corel draw or gimp, it is very simple to clone or heal the pixel out.
Oct 11, 2013 | Nikon Coolpix 5700 Digital Camera
How to fix my 65" toshiba white pixel problem
Thats caused by the DLP chip. Unfortunately most Toshiba models will end up having to have both the DLP chip and the formatter board replaced at the same time to fix the issue where as other models only require replacing the DLP chip alone to fix the white dots issue
Apr 06, 2013 | Toshiba 65HM167 65" Projection Television
My tv screen has a black spot
HI,
Are you sure that there is balck dot on the sreen. Check one more time is it any dust on the screen.
Black spot Means pixel of the Lcd sreen is fault. There are thousands of pixels in an lcd screen. when any of the pixel or a group of pixels become faulty the black spot will appear. Its not possile to rectify the problem other than replacing the LCD panle if its avilable. The avilability of lcd screen is very rare.
Ajin
Jun 16, 2012 | Emerson EWL20D6 Television
Spot on viewfinder and picture
Whoops! Clicked the wrong icon before. Here's my solution:
The spot is most likely a spec of dust that is on or in the cameras' lens or optical sensor (the sensor is the "film" in digital cameras). Dust is a problem for the SLR type cameras (the kind that have removable lenses) as the camera body is open when swapping lenses. Your camera does not have the ability to accept different lenses - so the chances of dust is minimized - but not impossible. When zooming, the lens extends and creates suction inside. When air is drawn in, a particle of dust was could have been brought in at the same time. Most of the time, dust will vary in appearance from a sharp, irregular shaped object to a fuzzy, rounder object - depending on whether the lens is zoomed in or zoomed out. A professional cleaning should be able clear this problem. Contact a camera shop for an estimate.
Other times, this is a much more sinister issue. The optical sensor has developed a problem. The optical sensor or simply "sensor", is a small rectangular semi-conductor that is sensitive to light. The size is often stated in "pixels". The are about 10 million pixels on a 10 megapixel camera's sensor. One of the sensor's has stopped responding to light focused on it by the lens. Depending on how it failed, this will appear either as a sharp, black dot in the same place of every picture if is failed "off" (this is called a dead pixel), or as a sharp colored dot in the same place of every picture if it failed "on" (this is called a hot pixel). Unfortunately, dead and hot pixels can not be fixed individually. The entire sensor must be replaced as a unit. This can be a costly repair depending on the camera make and model and sometimes it is better to buy new instead of investing money in an older camera. Again, consulting with a camera shop that does repairs or even the manufacturer in this case is in order for the best estimate of what repairs may cost. Good luck!
Jan 08, 2012 | Kodak EasyShare Z981 Digital Camera
When scanning dots show up in a vertical pattern
Printer DPI and PPI Ratings, General Dots per inch stands for the maximum number of tiny spots of ink that the printer can place in a straight line where the spots are theoretically small enough (i.e. ignoring spreading or smearing effects of ink on paper) that if placed in every other such dot position leaving white space between them, the spots can be individually distinguished. Pixels per inch stands for the maximum number of unique positions in a straight line that the printer can place an ink spot under control from the outside world, namely from a computer connected to the printer. Lines per inch stands for how close thin parallel lines can be printed and still be distinguished in the finished printout. The spaces between the lines count as "lines". Pixels per inch and dots per inch originally referred to the same thing. The printer mechanism was under the direct control of the computer and was physically positioned and placed dots as directed by the computer. Back then, most printer mechanisms were limited to placing dots only in positions suggested by a grid of dots X per inch horizontally and Y per inch vertically, for example 100x100 dpi Nowadays, many printers put dots "wherever they want" as opposed to in positions suggestive of a horizontal/vertical grid. Still there is a minimum dot size and a minimum dot spacing. A picture file (image file) represents pixels in a uniform horizontal/vertical grid pattern. And the printer needs to make a finished picture of the size, say 5x7 inches, that the user chose regardless of the number of pixels in the picture file. To simplify the process of relating the pixel count in the picture file to the possibly non-uniformly spaced dots on the paper, the printer or its supporting software may generate a temporary intermediate picture file with a set number of pixels per inch. The printer may have, internally, several choices of ratio of pixels to dots and the published rating can be the largest ratio except that the published rating may not exceed the dpi rating. Therefore there might be three "per inch" values involved at a given time, the pixels of the original picture file, the pixels per inch that the printer works with, and the dots per inch of the printer mechanism. Pixels per inch is usually not mentioned with printers. All printers come with their own software (including parts called drivers) to install on your computer. Usually the software does not let you exercise control over individual dots using your picture file. Rather the printer takes your picture file or data file and uses its own built in logic to lay down the dots and create the printed output. We are led to believe that a printer's ppi is usually a fraction such as a half or a third of its dpi rating. When a temporary picture file is created, there are at least two levels of software in use. High level software (which may run in your computer) takes your picture file and creates the temporary file. Low level software runs in the printer, takes the temporary file and controls the dot size and dot placement on the paper. Sometimes a printer is advertised using a phrase such as "300 dpi 1200 dpi quality". This means that the printer has some way of making dark edges on a light background appear smoother than the first number would otherwise suggest. A printer with 300 dpi 1200 dpi quality definitely cannot resolve alternating dark and light pixels less than 1/300'th inch each. But curved and diagonal lines and color boundaries should not have jagged edges suggesting individual dots rigidly positioned on a grid with a 1/300'th inch pitch.
Oct 24, 2010 | HP LaserJet 3050 All-In-One Printer
All picture taken found with 1 white dot at the location
The problem you are encountering is called a "dead pixel". Every ccd has several dead pixel, so it is quite normal. But I agree that it can be annoying.
The solution is to map the bad pixel and to substract them afterhands.
Go to http://chdk.wikia.com/wiki/Main_Page and download the latest firmware for you camera here http://mighty-hoernsche.de/.
It is a supplement to your camera that will open hundreds of possibilities, like making time-lapse recordings, doing your own scripts, shooting RAW,...as well as a feature for removing bad pixels.
All you have to do is to read! Yeah, I know, there are lots of things written :p
More specifically, here is the "how to use badpixel removal" explanation.
http://chdk.wikia.com/wiki/Badpixel_removal
Feb 27, 2009 | Canon PowerShot S2 IS Digital Camera
RED DOT
If the dot is not visible in print, but only on the camera's screen, the its only the LCD that is faulty.
If the dot is visible on screens and in print, then yes, it could be the sensor. Try taking pictures without the digital zoom. Chances are the dot is only visible with the digital zoom because the picture is interpolated.
If all else fails, you can try cloning out the spot in an image editor on the computer.
Dec 01, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Green and Blue spots on screen
Sounds like stuck pixels, you really can't fix that. Do some google research if you are curious what a stuck pixel is.
Oct 30, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Stuck pixel on 3000z
Sounds like you have a dust spot on the CCD, you should send your camera in for cleaning.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
