Question about Compaq (CDD480172) CD-RW Burner
Can't use DVD drive, says there are 2 drives there instead of 1
When I go into My Computer, It shows two DVD drives... I have no idea why. I also can't eject the drive, to get a disc out I had to use the paperclip trick. Any takers?
  • 3,153 Answers
Showing two drives can be caused by some of the burning software using what can be known as a "phantom drive" or "pseudo drive"
There are a few packages that can do this.
If however both drives read as the same exact model this would point to an error within windows that certainly needs looking at.
Some burning software can also LOCK drives and this may prevent opening them. Alcohol 120% is just such a software package that installs a drive by default.
If you have a flash drive these can be formatted to look like a cd or DVD so if you do have flash drives SD cards etc remove them and see if it goes away.
Posted on Sep 07, 2009
    Problem Solver:
  • 18 Answers
Maybe the power lead comming from the PSU into the drive is faulty or make sure both leads are securly plugged into the back..
My Pioneer DVD-RW 109 ATA does not show in computer list with windows 7, any ideas
Do you mean that it doesn't show in the "My computer" section?
Did you install this yourself? Or did it come with the computer.
If you did it yourself, you may have to check that the cords are properly connected. Also, if you are adding it as an additional drive, you may have to enable the SATA connector it's connected through the BIOS. Like SATA-0 may be your HDD, SATA-1 may be your primary DVD Drive, and if it's an additional one SATA-2 might be that one.
Thanks,
Please Rate.
Jul 08, 2011 | Computers & Internet
Dvd drive noisy put in dvd go to my computer driver is showing but wont play driver ejects
1. Try a different cd or dvd to see if it's reading any dics
2. Boot computer and try again
3. Uninstall the dvd drive from your computer (windows xp machine) , Right-click "My Computer-icon" -> Manage -> Device Manager -> DVD/CD-rom Drives -> right-click and select uninstall Restart the computer and it should install the drive again automatically Try reading the discs again
5. Update driver if available, see manufacturers website for driver updates
6. Try the dvd drive in another pc (if possible)
7. Propably faulty drive, replace the drive with a new one
Mar 06, 2011 | Computers & Internet
My dvd player used to work now it doesn't even show one is in the computer what doi Do?
Hi Maverick,
Can you get to device manager to see if your drive is installed and recognized by the system.
In windows 7/vista click start and type in 'device manager' in XP click start -> right cick on My computer and select properties and navigate to the device manger tab.
There will be a list of hardware installed in the list and you should find your drive under DVD/CD ROM drives. If there is a yellow exclamation mark - you need to update the drivers using the CD that came with the drive.
If the drive is not showing up in device manager you need to take your comp to a service center as there may be a fault with the controller.
Rhino.
Mar 05, 2011 | Lite On SHD-16P1S Internal DVD Drive
Everytime I try to tourn on the computer it will only show initialization and then after that the screen goes blank without even showing windows 7 interface.
Insert the Windows 7 DVD into your DVD-drive.
Restart your computer.
Tell it to "boot" from the DVD-drive, instead of from the 'C:' drive.
Eventually, click "Repair My Computer",
and work through the options.
Jun 11, 2010 | Computers & Internet
Optiarc DVD RW AD-5170a ata device. Cannot start code 10 error? any ideas why.
Possible cause of the problem:
1. Error 10 means that the drive driver is not properly or not installed in your computer.
2. You drive is broken.
Solutions:
1. Replug your drive wiring's inside the computer casing.
2. Check in the Device Manager in your computer if there is conflict in your drive. Go to Control Panel/System/Hardware/Device Manager to do this.
Nov 28, 2009 | Gateway (5500652) (  5500652)...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
I have a lacie 1TB exteranl hard drive and i cant get it 2 read on my dvd player via usb port...any ideas
Dows your DVD player supports reading drives of 1 TB capacity?
Check if the drive works on a computer!
Aug 24, 2009 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
Cd drive showing instead cd-rw/dvd drive
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Aug 02, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My computer doesn`t recognise disk in dvd drive
1. Make sure you use DVD's in good condition.
2. Reinstall the driver..( right click My Computer->properties->Hardware tab -> Device manager-> DVD rom-> right click Uninstall and again install using Dvd rom driver cd)
3. Clean The Drive lens using Dvd lens cleaner disc kit available in maket.
4. Removing DVD rom. opening it up manually and cleaning the lens with cotton( this tedious for novice users.. instead give it to servicing shop)
May 20, 2008 | Toshiba Computers & Internet
DVD READING PROBLEM
Hi , look in software store having a cd cleaner , to clean the optic laser of the dvd./ something block the reading of the data of the dvd disc.
Jan 16, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
Compaq (CDD480172) CD-RW Burner Logo
193 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
