Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Fridge and stove side by side
When new fridge installed by old stove the elements on stove began to melt side of fridge, how can we remedy this without moving appliances?
  • 4,070 Answers
I would get a piece of styrofoam insulation like they use on houses. It's about 1 inch thick and you can cut it to fit and paint it to match. Other insulation solutions should be available at Lowes etc.
Posted on Sep 07, 2009
  • 555 Answers
Sorry Claudial902, I believe you have a serious issue installing both appliances together, you must keep fridge and range separated.
I highly recommend you to check with your local building code.
Why does the terminal block keep melting on my kenmore range left front burner.
Brother Jeff, this happens all the time because the connections are not perfect, causing arcing at the point around the connection. This arcing makes for excessive heat and melts the block. I replaced the connections on my Mothers stove top with crimped connectors and it lasted a lot longer. They didn't burn out any more, she just needs a new stove. So your best bet is to use crimp on connectors instead of the OEM block that's melting from a loos connection.
Dec 01, 2014 | Kenmore Kitchen Ranges
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
This is a new fridge and the element located in the lower freezer behind the pull out drawer is red hot with water dripping on it? we had the same problem with our old fridge and this is why we replaced...
the element you see in the back of the freezer compartment is the defrost heater. your frig will defrost 2-3 times every 24 hours for 15-30 minutes. when its in a defrost cycle the element will get hot and melt the frost that has built up on the cooling coils from normal operation. the melted frost will then drip down ..some will hit the heater and sizzle,most will drip onto a tray and go down a small drain into a pan under the frig and then evaporate out.. Also ,it doesnt defrost at the same time each day., it is based on how much the frig runs and the electronic control will figure out when it it time to initiate a defrost..the red glow and the sizzling is normal and only lasts a short time....
Mar 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have the GE GSH25JFT side by side fridge. It's
We had the same problem with our 2 year old GE GSH25JFT. Had a Sears technician come out and said it was the main circuit board. He also stated this would be $400 by the time the repair is completed. I just ordered the part myself from a Sears Service Center for $146 plus shipping. I believe the install is as simple as: unplug refrigerator, disconnect water supply, removing six screws, pull out the old circuit board and install the new one.
Oct 04, 2009 | GE GSH25JFT
I cannot adjust the temperature on the elements of my stove top.
Hello Skyemahan,
I work on stoves with various problems all the time, and have never encountered a problem exactly like yours. You may get other answers, but here's my two cents worth: When I don't trust a stove, I replace it. Period. Hopefully, your's is old and you're ready for a new one. A new stove is much cheaper than a house fire.
Best Regards, --WoobieDog--
Jul 10, 2009 | Cooktops
FREEZER KEEPS WORKING NOT REFRIG
Yes, the defrost thermistat turns the element of when temps reach about 50 degrees F. The adaptive defrost tell the fridge to go into defrost. When the ice melts the defrost thermistat turns the element off.Whe can check the defrost thermistat if you like.
Your refrigerator has a adaptive defrost board inside the fresh food compartment hiding behind the control panel. That would be the first thing to consider that may be bad. But you also said you manually defrosted the refrigerator and it began doing this again about a month later. Take the model number and enter it in the search feature for model at it will take you to a page so we can look at the same refrigerator and work together to fins the answer. Below is a link click on that to look over your model. The adaptive defrost part number is 61005988
Let me know when you are ready, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
It is also possible the defrost thermostat is defective or a problem with a defrost element. Did you cange both element whith new defrost thermistat? Part number 61006199
May 11, 2009 | Maytag MZD2766GES Side by Side...
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven will not heat past 300 degrees (on bake command)
Remove the bottom plate on the stove which is likely help in place by a couple of bolts at the back. Remove the plate & inspect the bake element underneath. It is probably melted or broken in some area. It it does need replacing unplug the stove from the wall & remove one of the back panels at the back of the stove which access the wiring at this height on the stove. Disconnect the element.
Installation of new element is the same but in reverse.
Dec 09, 2008 | Whirlpool Kitchen Ranges
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
192 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
