Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
"Input select" button does not work on RD-XS35
I have a camcorder hooked up as input 2 in the DVD recorder. I also have a VHS hooked up as input 1.
When I push input select (to attempt to see either of the above inputs) nothing happens. Other buttons on toshiba remote work fine.
Toshiba is hooked up as component 2 to my sony tv.
Both inputs have worked in the past but it has been a long time since i used either. The toshiba has been connected and disconnected recently. All other features seem to work.
night71
  • 328 Answers
SOURCE: toshiba dvd recorder #rd-xs35
The full manual can be downloaded from http://www.tacp.toshiba.com/dvr/product.asp?model=RD-XS35
The cable box hook-up is on page 22. There are two ways: 8bc47e0.jpg
Posted on Oct 25, 2007
arthurroger
  • 170 Answers
SOURCE: lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Posted on Dec 13, 2008
SOURCE: I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Posted on Dec 16, 2008
welcomejee
  • 10594 Answers
SOURCE: i search owner manual forRD-XS35 and remote SE-RO144
Click Toshiba Support to download instruction manual of RD-XS35, file size is approx 11MB and will take time to download.
SE-RO144 seems incorrect / incomplete model number.
Posted on May 04, 2009
Mrteaze
  • 101 Answers
SOURCE: lOOKING FOR THE MANUEL FOR TOSHIBA HDD & DVD
http://www.tacp.toshiba.com/customersupport/
its here in PDF format just put your model number in
Posted on Sep 29, 2009
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Progressive Scan
Try these steps:
Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  1. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  2. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  3. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Sep 07, 2008 | Samsung DVD-VR357
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I dont have picture for recording
Welcome to Fixyah,
If yo can't see any picture please check your video cable connection.
>checked if the video cable is properly connected from dazzle to your camcorder.
>if you connect you camcorder,vhs,VCR using S-video then go ahead and click on option on step number 1 click on video input and then click on S-Video click also VHS input and then click okay.
>If RCA the same thing click on option then video input and then select Composite.
>Turn your camcorder,VHS,VCR on and then hit played button.
>checked your preview screen if the video image is now showing, If showing then start recording.
Regards.
Mar 11, 2010 | Pinnacle Dazzle DVD Recorder
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
DVDirect recorder. waiting for input signal? It shows the video on the screen but i push the record button and it stops and says waiting for input signal?! help!!!!
HAD the same problem! Called sony and it was fixed for me. I had a/v wires hooked up from my camcorder and from my vhs. I could see the video on the DVDirect screen. I would hit record and screen would go black and say "waiting on input signal". The fix: 1. turn the unit on. 2. Hold the on/off button for 30 SECONDS. (YEP, believe it or not) When I hooked the wires back up and did the same thing I had been doing. IT WORKED!!!! Hope it works for you!
Sep 22, 2009 | Sony DVDirect VRD-MC3 DVD Recorder
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Toshiba dvd recorder #rd-xs35
Oct 25, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Camcorder to JVC HR-A592U S-VHS VCR
you must select the input in your vhs. usually its a line input (wether 1 or 2). try to find it also using your supplied remote for the vhs. good luck!
Feb 09, 2007 | JVC HR-A592U S-VHS VCR
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
