Question about NetGear WGR614 Router
I am trying set up a wireless router with time warner cable. Having no luck. Please help.
  • 3 Answers
Sell the NetGear and get a Linksys/Cisco one. Always have problems with NetGear.
Posted on Sep 07, 2009
How should I configure Vuze on my new laptop? SMC8014W-G TWC Modem/Router. HP Envy Laptop w/Windows 8
JRod3,
Your new Laptop is capable of Wireless N theoretical transfer rate of 300 mbps with two antennas. Your router is wireless G at max. theoretical transfer rate of 54 mbps. I would recommend replacing your router with one that has wireless N. I use a Motorola Surfboard SBG6580. With some routers you can go into your settings and disable the firewall which will help with the speed. Firewalls can sometimes be redundant if you have a firewall in your operating system (windows) anyway. Before you run out and get a new router I would hardwire your laptop to the router (cat5E cable) you have now just to make sure you don't have a bottleneck somewhere else. Then do a speed test using your Vuze program. You may need to Port Forward your router, not always necessary..... you can get lots of info at portforward.com on your specific router. Depending on your speed that you are paying for from Time Warner you want to make sure you have the right router as well. Here is a list Buy Your Modem Time Warner Cable . If you reach your desired speeds hardwired to your laptop then I would get the new Wireless N router. Good Luck.
Mar 08, 2014 | SMC Computers & Internet
NetGear Gateway Access Problem
No to warner's locking the modem. 192.168.0.1 is the correct address for accessing the options within the modem. incidentally the Motorola wireless modem works better. Go on line to Netgear technical service and they will guide you through the task of setting up the system.
Feb 27, 2014 | NetGear WG602 802.11g/b Wireless Access...
I have Time Warner cable and use vonage. My set up is a D-Link Model: WWR-VR vonage router and an SMC8014W-G EZ connect wireless router provided from time warner. The cable internet is connected to the...
Welcome to Fixya. I would like to know the location of the wireless router and the wireless computer and the google tv. Are they in a same room, same floor? any walls or obstacles that can block the wireless signal? any other device that has the same issue with the router when put in a same room? Please provide the information needed to be able to fix the issue.
Thanks
Sep 09, 2011 | Linksys Wireless-G Broadband Router
Bought this netgear rangemax wireless router and don't know where the wires and stuf*** hook up to.the yellow ethernet wire on the back of router where does that go on the back of my computer terminal of...
Take the ethernet cable which is going from your Warner cable modem to your computer, and run it from your cable modem to the input connection of your router. Then take a second ethernet cable and run it from the router (ports 1, 2,3 or 4) to your computer. Log into your router's setup page (see your instruction manual), and set up all the passwords and wireless settings. Please read the instructions for specifics of your particular router.
Jun 26, 2010 | NetGear RangeMax WPN824 Wireless Router
Can you help me set up my home computer my time warner modem n vonage modem with my belkin router?
So you are trying to set up the router.
you can connect the router to the modem and the computer to the router.
Set up your router properly sothat your computer can go online through the router.
Pnce your computer is online through the router, then connect the Vonage to the router and it should work.
First make sure that your computer will be able to go online when connected directly to the Time Warner cable modem.
Click Here for step by step solution on how to set up router.
Nov 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Connection issue
Hi! I believe your having some issue with your router and I will be more than glad to assist you in this concern..Time warner cable is your isp and if the computer is connected directly to the modem, you have a perfect internet connection but if you are going to connect the cable from your modem to the router and you connect your computer to port 1 to 4 of your router it will not give u an internet connection. This is what we are going to do.
1. connect your computer that can get an internet connecttion thru time warner cable to the router on port1.
2. pull up a browser and type in the default gateway of the router, to check the default gateway of the router, right click the network icon on the lower right of the task bar and click status and it will show the ip address, subnet and default gateway, ex the default gateway is 192.168.1.1, u are going to type in the default gateway ip address to the url of the browser.
3. It will ask u for the username and password, by default the username is admin and the password is 1234 or just leave it blank.
4. It will pop up the setup page of the router and you have to look for the setting for doing a mac clone, you need to clone the mac address of your pc that can connect to the internet thru time warner cable modem.
5. once its done, save the settings and on the internet connection settings, manualy configured it to auto-dhcp. save the settings.
6. once its done..unplg the power of the computer, router and modem.
7. cable connection should be, cable from the modem goes to the WAN port of the router and connect cable on port 1 of the router to your computer on the lan port.
8. Plug in 1st the power of the cable modem, once all lights are lit then plug in the power of the router, once all lights are solid on the router, like the power, WAN, u will notice that there is no light on the port1, computer is still off, once the computer is on port1 will lit, then power on the computer..once computer is completely boot up, pull up a browser and it should gives u an internet connection.
9. Once you have an internet connection, u can access again the setup page of the router to setup the wireless connection settings.
10. If you are going to connect another to the existing router that is conneted to the time warner cable. that is possible, but before u connect the 2nd router to the 1st router..
a. connect the 2nd router to a computer to set it up..you have to access the setup page of the 2nd router.
b. once you access the setup page, there is a menu for the lan settings that is for the router side. u need to change the 3 octet of the ip address of the 2nd router. ex your 1st router ip address is 192.168.1.1 and the 2nd router ip address is 192.168.1.1 to change the 3 octet of the 2nd route, the 2nd router ip address should be 192.168.2.1. then save the settings..
c. the router will reboot and need to access the setup page of the router by using the 192.168.2.1 and u can set the wireless connection settings.. once its done..
d. cable connection should be---cable from the time warner cable goes to the WAN port of the 1st router, connect a cable to port 4 of the 1st router going to the WAN port of the 2nd router.. this process is called cascading two routers on a network.. this should work.. good luck
Aug 16, 2009 | ViewSonic (DHWMG120) Router
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Time Warner Cable
you have no account with the old phone company? if so you need to call them and they will walk you thou the setup.
Dec 16, 2007 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
NetGear WGR614 Router Logo
208 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
