Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Can i get a diagram for model # 10455A for auto chain oiler hoses
Chain saw gas powered
looking for diagrams of oil system for model # 10455A
    President:
  • 2,220 Answers
What is the Make?
Posted on Sep 07, 2009
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 | Garden
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
455 chain saw does not seam to be oiling the chain enough,checked an cleaned oiler chain an bar ,i cant find my book but i know it can be adjusted but dont know how
Caution it is probably only a 3 position oiler, forcing it beyond either stop may cause failure. The 2009 om (may not be your saw) adjustment is on page 33 of the Operator's Manual (below).
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Jan 05, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Mcculloch em300s electric chain saw stopped oiling the chain. I noticed the oil had all flowed out in storage shed and when I refilled it and used it I noticed the chain and bar were dry.
This is a little complicated so I’m going in small steps.
Click “Electric Chain Saws” The model number of your saw is probably on a tag affixed to the bottom. The tag also displays the serial number.
If it is a 300S the hyphen is the bar length.
I looked at the 300S-16 (same oiler parts as -14)
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Item 15 has a filter on the bottom check it first, insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). If good I’d look closely at item 17. I can’t get enough detail from the IPL but that is the logical culprit.
Oil systems on all Mac Electrics appear pretty basic. Good Luck
Lou
Nov 08, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
The bar oiler is not working. when it sits for about a week it will drain all the bar oil. The last time I used the saw the first tank of gas it oiled good after that it will not oil the bar. I removed the...
Is this a new saw? If yes please contact Husqvarna about a warranty (2 years) repair. I think you already performed part 1 below.
I've 7 chainsaws. 6 of them oil my bench if I forget to drain the oil tank.
You don't give us a model number not all saws have oiler adjustments. An IPL of your saw with oiler detail can be found here:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
Oil System Plugged.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Nov 04, 2009 | Husqvarna Chain Saw 20" Bar
Oiler not working
Had you provided the model number we could have provided a more complete answer. What little oil system routing detial there is resides on the IPL. It can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Sep 30, 2009 | Ryobi Factory Reconditioned 18" 40cc...
The auto oiler for the chain is not working, what should i look for
Hi
try this steps and proceed from one to the next :
1. make sure you filled oil
2. clean the chain oil container with gasoline
3. try thinner oil
Jul 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oiler not working, need diagram to fix
HI. IF YOU GOT YOUR SAW NEW THERE SHOULD OF BEEN A DIGRAIM SHOWING YOU HOW IT WORKS. THATS THE BEST YOU WILL GET UNLESS YOU KNOW SOMEONE AT THE SAW SHOP BECAUSE THEY DON'T WANT YOU TO KNOW HOW TO TAKE THEM APART AND PUT THEM BACK TOGETHER. GOOD LUCK. JIMBO
Jun 25, 2009 | Husqvarna Forest & Garden #952802239 235E...
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Ryobi 40 cc bar oiler not working
hi customweldi
check the oil filter,the oil line ,the oiler and the worm gear.Clean the bar and the oil hose.
the best savumihai71
Nov 30, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
123 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
