Question about Dell Inspiron 1501 Notebook
Dell 1501 Error- AC Adapter is not recognized
I receive the error on Dell 1501 Inspiron laptop. AC Adapter does power laptop but Battery will not charge.
    Problem Solver:
  • 18 Answers
Myabe the battery is faulty have you tried replacing it?
Posted on Sep 07, 2009
Testimonial: "Don't have an extra battery to test so was hoping the error was causing the battery not to charge. "
  • 3 Answers
Check the lights on your battery.. its an indicator if your battery is healthy or not..
Have a dell inspiron with original ac adapter and battery. i get error message saying that the AC adapter cannot be determined is not recognized by dell and need a dell 65W AC adapter. I have the...
The adapter could be faulty or has failed slightly and is below the operating limits. This means you probably need to replace the power adapter.
Nov 01, 2010 | Dell Inspiron 1501 Notebook
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
May 19, 2010 | Dell Inspiron 1501 Notebook
Will the power cord for the Dell Inspiron 1501 fit the Vostro 1500?
AC adapter for both systems belong to D-Family 65 W lead-free AC adapter So you can use the Ac adadpter Note :- The Vostro 1500 discrete version requires the 90 W AC adapter. Without it, you will receive an error message indicating the wrong AC adapter type, the CPU speed will downgrade, and the battery will not charge.
Dec 21, 2009 | Dell Inspiron 1501 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Ac adapter not recognizd.
You do not need a new laptop but i believe you need a new battery.RICHARDM69
Dell Inspiron 1501 AC Adapter error message
The Dell 1501 ac adapter (possibly other Dell’s as well) has been known to be problematic because of its lack of a plug to jack secure fit. You will notice that the plug can all too easily be pulled from the jack, as opposed to other systems where the plug fits more securely onto the jack. The plug and jack combination is poorly designed so that over time, the plug will come unseated depending on how much movement the machine is subjected to. This will result in power error messages or outright power-up failure. So before assuming you have a faulty adapter, make sure that it is not just a loose plug that is causing the problem. If you look inside the jack, you will notice that there is a 3mm region of non-conductive material nearest the surface of the jack. Use a strip of standard electrical tape 3mm wide and long enough and wrap it around the base of the plug (you may need more than one layer of tape to get a good fit). I have used this method to secure my plug and it has served me well. If the tape comes undone over time, just simply replace it. A more “elegant” method would be to use an “O” ring of the appropriate size (about 6mm) around the base of the plug in lieu of the tape.
Jul 26, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
500 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
