Question about Motorola Mobility RAZR V3
Phone says insert sim when turned on, dosent charge like before...
See above
    Sergeant:
  • 316 Answers
Remove sim from phone and gently rub the copper side with a pencil eraser then wipe off the excess rubber and replace the sim.
if this doesn't work then your sim reader may have died and a tech will have to repair this
Posted on Dec 09, 2007
I put my samsung on it dosent work couse my sim is not registed
1. If it is a new sim card wait till the service provider registers the sim.
2. If it was already working previously insert another known working sim card. If same message comes clean the contact points on the cell phone.
3. If above 2 dont work your phone IC is corrupted and you need expert help.
Try the above. I hope this helps
Mar 10, 2011 | Samsung Cell Phones
My phone said to insert sim but ive inserted my sim and tried to take it out and insert it again it still say insert sim
YOU NEED TO REPAIR IT.. BUT ITS DIFFICULT TO DO YOUR SELF. I REPAIR PHONES BUT I PREFER TO SEND THEM TO GOLDENLEPRICON. COM THEY HAVE A FAST TURN AROUND AND THEY CHARGE VERY CHEAP.
Dec 18, 2010 | Sony Ericsson Walkman W705 Cell Phone
Sony ericsson w995 won't charge. On attempting to charge phone says "Battery can not be charged insert a Sony Battery" (the battery is the original battery) once that screen goes it says insert SIM even...
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 16, 2010 | Sony Ericsson Walkman® W995 Cell Phone
N95 on offline mode, not coming in general or other mode, when any sim card inserted ' sim card not valid'
hi malik, you're still having the same problem though, now you know that your phone has the error..
try these steps on your N95 phone.
1. on your keypad, press *#7370# for soft reset
2. then, insert your sim back, check if your sim has been recognized, if it doesn't do step 3,
3. on your keypad, press *#7780# for hard reset once finished, insert your sim back and switch on. if the phone still doesn't recognized the sim, then do step 4.
4. on your keypad press *, 3, call key and power switch at the same time, to make a hard formatting on your phone and setting it back to its factory setting.
>> under above steps, you need to make sure that, battery is fully charge, if not, fully charge battery before doing all the steps above. don't forget to remove your sim every time you do the steps (so as the sd card if your phone has it).
>>>please make a note that, if all of the above steps has failed,or nothing happened and still you have the same issue, then go now to a phone repair shop and have them check your phone, it can be a hardware problem. if your phone is still under warranty, try not to do the steps above, instead, go back to that phone store and return your phone and show them your problem, so they can immediately replace it.
>>>also, make sure that your phone is network unlock and can be use with other network sim.
good luck.
Feb 24, 2010 | Nokia N95 Cellular Phone
My signal keeps sayin SOS and it tells me to insert sim card when
1.check the sim card if it is properly inserted.or try other sim card.
2.did you turn on your wifi?turn it on to have a signal from your network.
3.Is it unlock/openline already?
4.if the above mention is still not working its already a hardware problem.
Jul 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I can't turn off my Samsung SGH - D880
Yesterday I also got the same problem on Samsung DUOS SGH-D780!
I found temporary solution how to drop this error message and run the phone normally, but after next reboot it often become again. I will ask Samsung tech. support about this, but now here is the emergency solution:
1. Turn OFF the phone (by removing the battery)
2. Move out all the SIM cards from the phone
3. Insert the battery again (BUT DON'T TURN ON THE PHONE, just insert the battery)
4. Insert a charging cable into the phone and insert the adapter in wall outlet
(then I see the loading screen for the short time and after that CHARGING icon appears)
5. After that turn ON the phone. It will start in no-sim mode.
6. Turn OFF the phone
7. Remove battery, insert SIM-cards, insert the battery.
8. Turn ON the phone
After that it gonna be work good until next reloading...
Feb 27, 2009 | Samsung D880 Cellular Phone
Insert sim
Try rigorously cleaning the sim card and phone connections (also battery connections - after reading forums the batteries on V3's are often to blame for their problems) with a cotton bud then leave the phone off without the sim card in it and charge it overnight. Then put in the sim card and turn the phone on. This might help. My V3 often says Insert SIM and it is very annoying so i'm getting rid of it but those methods have worked for me.
Hope this helps
Mowcius
May 12, 2008 | Motorola Mobility RAZR V3
Sony Ericsson K800i
The phone is probaly locked on a different network, have your phone unlocked and it should work.
Go to:
http://www.kingmobilephone.com/pages/remote-unlock.php
Dec 28, 2007 | Sony Ericsson K800i Cellular Phone
Nokia1600 problem
ask ur service provider about ur sim card registration or else ur handset sim card slots r damaged....
Oct 03, 2007 | Nokia 1600 Cellular Phone
Motorola Mobility RAZR V3 Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
